Old 06-19-2023, 05:17 PM   #1
2023ZL1RapidBlue
Drives: ZL1, S2000
Driver's seat memory-doesn't always work
Hello folks,
Has anyone experienced the seat not either moving upon exit or moving forward upon entry randomly?
Both options are set up in the infotainment vehicle settings but this thing goes haywire sometimes by not moving the seat accordingly.
What I've done in the past is go into the settings and disable and enable it back on again and it works again consistently for like a week or so.
Any clues here?
2023ZL1RapidBlue is offline   Reply With Quote
Old 06-19-2023, 05:31 PM   #2
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
Same with mine from day one. I just learned to live with it.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 06-19-2023, 06:00 PM   #3
2023ZL1RapidBlue
Drives: ZL1, S2000
Ok, at least I'm not alone.
Old 06-19-2023, 08:57 PM   #4
Looks like I'm lucky, mine has worked 100% of the time for 5 years. One would think eight model years should be enough to iron out all these kinks, but hey,this is GM
If it makes you guys feel better, my wife has a Traverse with a known flaw that GM didn't fix from 2009 (first MY) to 2017 (last MY before refresh), I'll have to take it in, the gauge cluster needs to come out and get replaced... unless she can live with it (hint, hint )
Old 06-19-2023, 10:19 PM   #5
willzilla
D3RPZILLA
willzilla's Avatar
Drives: 2021 Camaro ZL1 a10
No issues as of yet but I've pretty much set my seat position and have never adjusted it since and I don't use the auto exit stuff as I figure this will wear out the motors fairly quick with how things go with cars these days, lol.
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy
YouTube Playlists: Performance Mods | Show Mods | Other Mods
willzilla is offline   Reply With Quote
Old 06-20-2023, 06:43 AM   #6
BanOne
Drives: 1977 Pontiac Trans Am
Seat not moving
So it is not a glitch it is a design. I noticed this as well and it has to do with setting the parking break before you turn the car off (I am assuming you have a manual). If you set the brake and then turn the car off the seat will go to the exit position and then when you get back in it will return to the driving position once the car is started. If you set the brake after you turn the car off the seat wont move.
BanOne is offline   Reply With Quote
Old 06-20-2023, 08:18 AM   #7
BunnyBoy
Drives: 2017 ZL1
My seat moves forward when I open the door... I'm 6'3 so I have to get my hand down fast enough to stop it from smashing my legs. Not sure how I stop it from doing this.
BunnyBoy is offline   Reply With Quote
Old 06-20-2023, 08:33 AM   #8
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
My 2017 ZL1 is the same way which is not an issue with me.
Old 06-20-2023, 09:34 AM   #9
gblaue
gblaue's Avatar
I think If I start the car in neutral, the seat does not move into the memory location, But, if I start the car in `1st gear, it will move most of the way into the memory location. It's weird.
Old 06-20-2023, 09:43 AM   #10
FarmerFran
FarmerFran's Avatar
If vehicle is in running it does not work. Car has to be off then it will activate when you open the door. I have tested this a few times.
<Insert Cars You Own Here>
Old 06-20-2023, 09:44 AM   #11
L98 Z28
L98 Z28's Avatar
Drives: 2017 ZL1 6spd Convertible NFG
The parking brake has to be set for it to move forward when I get in. Took a while to figure that out. It always moves back for exit. This is a 2017 M6.
L98 Z28 is offline   Reply With Quote
Old 06-20-2023, 03:34 PM   #12
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
Set your seat where you want it to go when you turn off the car. Hold the SET button until it beeps, then IMMEDIATEDLY press the Seat Exit button. Then it should start moving to that seat seating when you turn off the car, instead of cramming you forward into the dash.
My Camaro Journal
Old 06-20-2023, 04:14 PM   #13
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Excellent. This has been bothering me since I got the car. I'm sure it's in the manual, but who reads that. Now I know why the seat never moves to my set position when I start my car in my garage... I never set the parking brake in my garage. Easy solution! LOL
thanks for the intel!
Mods being installed-
RobZL1 is online now   Reply With Quote
Old 06-20-2023, 04:18 PM   #14
gblaue
gblaue's Avatar
Exit works every time. It’s a crapshoot whether I need to manually push the preset button, or not, to move the seat into position.
