06-19-2023, 09:22 AM | #1 |
Drives: 2016 Camaro SS Join Date: Oct 2021
SmoothBoost with a centri
So Josh peaked my interst in the smoothboost and I decided to pick one up as I really like the idea of being able to turn down the boost on the fly for street driving.
My D1sc makes about 11.5 at full throttle and on street tires that can be a little too much going through 3rd and 4th, very easy to get sideways. For those unfamilar SB gives you a wastegate that takes the place of the BOV on the procharger intercooler. Now instead of being operated by engine vac/boost it is controlled by throttle input that can also be adjusted by a control knob. With the knob at max the wastegate operates very similar if not identical to the BOV and max boost is the same. As the control knob is dialed back, max boost is also dialed back, with it set at halfway boost is dialed back to around 2-3psi. Not as much range as I had hoped for because anything less than halfway pretty much keeps the gate wide open. But between halfway and full on I can adjust it to hit pretty much any boost level. Now for me the best part is being able to have a scramble button that when pushed instantly closes the wastegate giving full boost. With my car I keep the knob set at 2 marks down form max which gives me about 8psi then as the rpms come past 5k mash the button and get full boost and a pretty good kick in the pants. This might be very useful at the dragstrip where with my Nitto drag radials 2nd and 3rd are very tough to keep traction in. It will also be even more useful next year after I add more fueling and turn the boost up a little more. Install was pretty easy, wastegate is a direct replacement for the BOV, it is a little longer and was just making contact with the inside of my bumper cover, so I trimmed just a little so it had a bit of space. Power/ground inside and tapping into the pedal wire at pin #5. Scramble switch just grounded one side and the other to the input on the SB. Running the wires through the firewall was the hardest part. There is also another input on the SB that when triggered will cut all boost, either from a button or an external controller signaling a leanout condition. Also works with your current tune with really no changes. Not exactly cheap but a well built and does exactly what I was looking for.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods BTR stage 3 cam - Circle D converter American Racing headers - Borla S-type |
06-19-2023, 10:52 AM | #2 |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
This is awesome. I'm pretty set on getting one for a Magnuson 2650 build. I've kept the car at ~900whp because anymore seemed to be too much for the street and reliability. Now I can push for as much as I want with the idea of turning the boost down for the street and less stress on the engine.
Only issue I'd imagine is the blower will still be spinning at max speed and generating some heat. |
06-19-2023, 11:13 AM | #3 |
Yes still spinning the same just dumping all the pressure out the wastegate. Not sure if just dumping it thru the wastegate would generate less heat as it is not pushing against something but just dumping into open air.
06-19-2023, 11:25 AM | #4 | |
Thank you Al Oppenheiser!
With adiabatic compression, heat is a direct function of pressure-change. So if with the waste gate open you have less delta-P then you will have less delta-T. |
06-19-2023, 11:53 AM | #5 |
Used to own a ZL1
Would the same apply to a PD blower dumping the air directly into the engine through the bypass? Even if it's spinning pretty fast but generating low pressure would it be much cooler?
06-19-2023, 12:28 PM | #6 | |
06-19-2023, 03:10 PM | #7 |
Drives: Chevrolet Camaro Join Date: Apr 2022
That is a nice option to have. Can you flip it over so the actuator isn't visible behind the grille?
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT4 HPFP, LT4 Injectors, JMS BAP - 722WHP
06-19-2023, 03:59 PM | #8 |
Nope would have hit the belly panel.
06-19-2023, 05:43 PM | #9 |
Does it drop boost across the whole rpm range, or only limit peak boost?
06-19-2023, 06:29 PM | #10 |
Used to own a ZL1
06-19-2023, 06:41 PM | #11 |
I was hoping it could keep midrange boost, but limit peak.
06-19-2023, 08:06 PM | #12 | ||
06-20-2023, 09:18 AM | #13 | |
Once you go full throttle you will get max boost for the level you have it set. With it set to max it drives almost identical to before, with it turned down still the same but you just loose boost/power. But with the centri you do not really loose any power below 3k, but where the boost would normally hit it is just scaled back according to where it is set. I found this really nice especially for 2nd and 3rd where I have had real issues with traction above 3500rpm. The scramble button gives max available boost immediately which is fun. I have a log where I had boost turned down and mashed it around 4500 in 4th, where the boost had been on it's typical upward climb it jumped straight up on the graph. Felt like hitting the nitrous back in the day. Nice having a quick street car with good manners and with the press of a button adding big power.
06-20-2023, 09:43 AM | #14 | |
Used to own a ZL1
Gives me hope for my car which I personally felt was too fast to be fun on the street. |
