![]() Drives: 2020 Rally Green ZL1-1LE Join Date: May 2020
2020 RGM ZL1-1LE 31,000 miles
Selling my 2020 A10 Rally Green Metallic ZLE as I've ordered a new car. 31,000 miles. Will continue to add miles until sold.
Has been tracked at 6 events at Putnam Park. Trans and diff fluids changed at least once per year. Diff changed at 500 miles first time. Mobil 1 synthetic engine oil for oil changes. 50w always used for track events and then changed back to 0W-40 after events. BMR heim joint rear suspension rods (red color) with rubber joint covers installed Never tuned-maintains remainder of factory warranty Stock supercharger replaced at 20,000 due to a bearing starting to make noise Comes with Bronze BC Forged RZ053 wheels with PS4's and factory ZLE wheels with Supercar 3R's Jackpoint blocks at pinch welds AntiGravity Battery, also have stock battery Aftermarket heat exchangers from Speed Inc Track alignment Ti shims on brake pads SRF Brake Fluid-flushed yearly Front cover PPF Green air filter rock guards at all 4 corners "Camaro" factory rubber floor mats used since new and basic carpet mats never used "Camaro" rubber factory trunk mat Build date is 11-19-2019 Area on rocker covers and lower Qtrs paint behind doors have small chips from track days Wear on drivers side seat bolster rubber air deflectors under front bumper cover worn and could use replacement-comes in kit from GM Has misc small rock chips expected at 30,000+ miles car sits outside regularly Has red knee pads on console only. Why? Mistake from GM I guess. I was not aware they should have been on doors too when I took delivery. Car was ordered by me from a St Louis area dealership. Will add pics this weekend. Located in Springfield, IL $67,000 Last edited by GreenZLE; 06-17-2023 at 10:48 PM. |
This shouldn't take long to sell. I've seen people pining after the RGM Camaros. There might even be some "Wanted: RGM" threads if you look back a bit.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
![]() Drives: 2020 RGM ZL1 1LE Join Date: Sep 2011
Really hard color to come by! GLWS
2020 Camaro ZL1 1LE Rally Green Metallic
2010 Camaro 2SS/RS (Gone but never forgotten) -FAST LSXR 102 -Vortech V3 SI Supercharger -Pulleys -Shake N Bake Cam (233/248) -ALKY meth injection -TSP 1-7/8” headers -Catless X pipe -NPP w/ M2W -Eibach Coilovers -22" Dub S116 Wheels -Fesler Aero Package -3M matte black wrap |
![]() Drives: Camaro SS 1LE Join Date: Mar 2023
If only it was a manual! GLWS
Thanks for the comments everyone!
