![]() Drives: 2016 Camaro SS Join Date: Apr 2023
Hello guys!
I currently have 2 tuners (the I2 and the HP Tuners). I used the I2 a while back on my 11' Camaro but I flashed it back to stock. Now, I still have a GM licence available but I'm looking to sell it later on cause HP Tuners is so much better for the advanced features ![]() Anyways, I was thinking.. Could I flash my 16' SS with the I2 tuner (93 Octane tune). Read the ECM with HP Tuners and save it. Go back to stock with the I2 to free up my GM Licence and compare my Stock tune with my DS tune ? Then, once I got all the settings right flash the car with HP Tuners ? PS: If this works, I'm whiling to share the HP Tuners dump tune ![]() Thanks! |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: May 2019
Good question IMO because I’d suspect the tune file would be locked by the Diablo. Hopefully someone has an answer for you.
![]() ![]() Drives: 2019 2SS Camaro Join Date: Apr 2012
Just try it, then u will know
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 6th gen Join Date: Aug 2013
Yes
Quick question tho, Do you think I could flash the Diablo tune with the modification I've done to my stock tune already ?
Disabled V4 mode (ECU + FSCM) Disabled TCC slip tables. |
![]() Drives: 2020 Camaro SS 1LE Join Date: Apr 2022
Is the diablo tune even worth it? It’s probably really not a good tune regardless.
