Old 06-15-2023, 09:39 AM   #1
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Adding nav
Got a 2023 2SS off a dealers lot. No nav, but dealer says they can add it for $150.
Just called another dealer near my home & they say it can't be added.
Can this upgrade be done & if so, is it by changing the head unit or by adding a card & programming the system?
Please - no "why add nav" comments/questions.
classicrockr is offline   Reply With Quote
Old 06-15-2023, 02:49 PM   #2
There definitely is a navigation upgrade package, I only found this link where it's pretty expensive, but you can have the dealer confirm it's the same thing: https://infotainment.com/shop/interi...radio-upgrade/
By the way, a similar upgrade was not offered from model years 2016 to 2018, so I think the other dealer simply didn't have up to date information.
Old 06-25-2023, 08:28 PM   #3
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
the older stuff had two different hmi's where the standard non nav hmi didn't have gps hardware on top of not having the firmware for it. so a cheap software flash wasn't an option. you have to jump thru a bunch of hoops even if you could find a dealer willing to try.
older stuff had to go the gen5diy route if they wanted nav hmi. New stuff probably is just one part and the only difference is programming.
Old 06-25-2023, 09:03 PM   #4
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
GM released an SD card that was supposed to add NAV to vehicles that didn't have it. Below is a link to a web article about it with the GM part number. I don't know if it is still available or compatible with your car and infotainment system. Maybe this is an option for you.
https://gmauthority.com/blog/2019/09...9-2020-camaro/
Old 06-25-2023, 09:34 PM   #5
SS_Don
SS_Don's Avatar
Drives: '22 Camaro 2SS
Page not found
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4 | Range AFM Disabler
Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo | Footwell Lighting | Umbra Sequential LED Taillights
ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Banks Data Pro and Pro gauges in ZZPerformance pillar pod | Paddle shifter extensions
SS_Don is offline   Reply With Quote
Old 06-26-2023, 05:13 AM   #6
Eos
Eos's Avatar
Drives: Camaro Coupé 2.0T AT8 (EU version)
Originally Posted by SS_Don View Post
Page not found
The full URL:
The car must be equipped with the IOS 8-inch display in order to be updated. 7-inch screens are not compatible.
Assigned RPO Code is S54 and GM part number 84250952.
See you!!,
Eos
Eos is offline   Reply With Quote
