Old 06-14-2023, 09:18 AM   #1
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
Coolant hose connection questions
Does anyone know the torque specs for the bolts on coolant hose connection to the engine block in the picture?
Also, does anyone know the type of bolt? I am installing the catch can on one of those bolts and the bracket is about less than 1/2 inch thick so i would like to get a longer bolt. Would that longer bolt even be necessary? I have seen in other MY they changed the style of how that part connects to the engine block.
Old 06-14-2023, 01:48 PM   #2
CalgaryZL1
CalgaryZL1's Avatar
Drives: 2020 Chevy Camaro ZL1
Sorry I don’t, I chose to put it on the drivers side of engine
Old 06-14-2023, 01:51 PM   #3
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Photo is blurry so I can't see what you see. But here is the LT4 stuff from the whole torque table. New bolt should have the same markings as the current bolt, just be longer. You can usually deduce the bolt spec from the torque spec.
Engine Oil Cooler Bolt 10 N.m (89 lb in)
Engine Oil Cooler Hose Fastener (LT1, LT4) 10 N.m (89 lb in)
Engine Oil Cooler Hose Quick Connect 34 N.m (25 lb ft)
Radiator Air Lower Seal Bolt 2.5 N.m (22 lb in)
Radiator Surge Tank Nut 6 N.m (53 lb in)
Radiator Upper Mount Bracket Bolt 9 N.m (80 lb in)
Supercharger Water Manifold Fastener (LT1, LT4) 10 N.m (89 lb in)
Thermostat Heater Shield Fastener 5 N.m (44 lb in)
Upper Charge Air Cooler Bracket Bolt (LGX LTG LT4) 9 N.m (80 lb in)
Water Inlet and Outlet Pipe Fasteners 9 N.m (80 lb in)
Water Outlet Bolt (LTG, LT1, LT4) 10 N.m (89 lb in)
Water Pump Bolt (LT1, LT4) 10 N.m (89 lb in)
Air Bleeder Valve Pin Screw (LT4) 2.8 N.m (25 lb in)
Charge Air Cooler Bracket Bolt (LGX LTG LT1 LT4) 9 N.m (80 lb in)
Charge Air Cooler Bracket Bolt (LTG LT4) 22 N.m (16 lb ft)
Charge Air Cooler Coolant Pump Clamp Bolt (LT4) 9 N.m (80 lb in)
Charge Air Cooler Radiator Bolt (LT4) 9 N.m (80 lb in)
Charge Air Cooler Upper Bracket Nut (LT4) 5.5 N.m (49 lb in)
Drain Plug (LT4) 9 N.m (80 lb in)
Engine Coolant Air Bleed Valve (LT1 LT4) 12 N.m (106 lb in)
Engine Coolant Fan Bolt (LT4) 9 N.m (80 lb in)
Engine Coolant Manifold Bolt (LT1, LT4) 25 N.m (18 lb ft)
Old 06-25-2023, 10:41 PM   #4
Wuiquen
Wuiquen's Avatar
Better pics below. It is the coolant hose attachment to the engine.
Old 06-26-2023, 07:34 AM   #5
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
That is the thermostat housing FYI.
Old 06-26-2023, 07:53 AM   #6
89 inch (not foot!) pounds, see below
Old 07-02-2023, 07:34 PM   #7
Wuiquen
Wuiquen's Avatar
Thank you all for the assistance. Do you all think I need a longer bolt if I add a bracket to one of the bolts? The bracket is like 1/4 inch. I suppose I can go to a lower store and get a longer bolt for piece of mind.
