Old 06-12-2023, 01:37 AM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
NEW SMG Drop In Fuel PUMP ???
Hey guys... anyone else seen this yet?
Wondering why i have not seem this on the boards yet...
Anyone running it?
Would love some feedback... i like the "in tank" version and cost!
https://smgspeed.com/products/smg-bi...and-gen3-cts-v
Old 06-12-2023, 11:57 AM   #2
w.ross
Drives: 94 Toyota Pickup
This is the first time I've seen this low side pump mentioned, but I have wondered why there wasn't a product like this out there since I started researching the 6th gen ZL1's 4 years ago prior to purchasing. This looks like it would work for my needs and is much cleaner than the external aux pumps.
w.ross is offline   Reply With Quote
Old 06-12-2023, 12:21 PM   #3
Xelor
Drives: 2022 ZL1
This looks like a nice product
Xelor is offline   Reply With Quote
Old 06-12-2023, 01:38 PM   #4
ZL1...SON
Drives: 2021 Camaro ZL1
FYI, there is another similar product called the Frankenpump if i remember correctly. Also, an employee of the Katech has spoken about a new product that is supposed to be coming to market very soon which is supposed to be better than all currently available. Take that for what its worth.
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, BMR Cradle Lockouts, Atturo 315 AZ850DR
ZL1...SON is offline   Reply With Quote
Old 06-12-2023, 01:57 PM   #5
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
Is the low side the place where fuel drops out 1st? Assuming it is, with all the fuel it can take, where does the high side start to be the limitation?
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 06-12-2023, 02:25 PM   #6
SOCAL.M6.ZLE
I am told that the high side drops first...
I am officially out of injector at 730rwhp running 12 pounds of boost and E33... Even with a 32% fuel lobe cam, im told the HPFP would be next... then the low side last... as i currently have a JMS booster.
I think injectors will add another 30rwhp
HPFP maybe 20-30... then loadside would give me about 50 more rwhp...
Old 06-12-2023, 02:42 PM   #7
Xelor
Drives: 2022 ZL1
Personally Totally against Voltage Boosters.
Pump is the proper way to go.
I like that pump from SMG.
Old 06-12-2023, 03:16 PM   #8
Katech_Mike
Drives: 2015 Camaro ZL1
Our set up will keep the bucket functioning 100% as the OEM intended as well as support higher low side fuel pressures.
There is nothing on the market currently that achieves both of those things.
It will be worth the wait.
Katech_Mike is offline   Reply With Quote
Old 06-12-2023, 03:21 PM   #9
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Fuel system components do not add power, they "support" more power.
First thing that drops is low side. Jms boost will help extend the high side. Then high side pump runs out next with stock cam, with a 32% lobe then you run out of injector.
XDI +30, LPE DI pump, SMG tank pump should support around 800whp in E80, and probably around 900whp on E60. If you want Full E above 850whp then you need +65 injectors.
At current prices on DI fuel system components Port Injection is a more affordable solution but adds complexity far as tuning.
That being said, I would expect your setup to go a little further.
I have LT4 injector/HPFP setups supporting 780whp on E50. Tuning makes a big difference on these fuel systems. SOI/ commanded rail pressure/ and target AFR plays a huge roll in maximizing fuel system capacity.
Old 06-12-2023, 03:31 PM   #10
ZL14ever
Drives: 2018 Camaro ZL1 A10
Any idea when is it going to be released?
ZL14ever is offline   Reply With Quote
Old 06-12-2023, 03:43 PM   #11
Sillysspeed
Drives: 22 LT1
I’ve never had one til this car. It actually works really good with the direct injection
Sillysspeed is offline   Reply With Quote
Old 06-12-2023, 03:46 PM   #12
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
King beat me to the punch. Getting the low side rock solid is priority number one since that is needed to support either upgrade: big DI or added port injection.
Old 06-12-2023, 05:05 PM   #13
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
No disrespect, especially since I've been waiting to see the new lowside you guys are gonna offer, and I'm running one of your oil pumps. But doesn't the smg big boy pump and ogsolutions frankenpump both retain factory bucket and oe functions, are direct plug and play drop in, and pushes over 400 lph at 70 psi supporting over 900whp supposedly with proper modifications?
Or did I misinterpret your response?
Old 06-13-2023, 08:26 AM   #14
Katech_Mike
No disrespect taken. We have inspected and tested most pumps on the market.
The SMG bucket is modified and is not sealed like stock. You lose low fuel level performance. That pump stops flowing at LT4 lowside fuel pressures. It's designed to run at 50psi per their website. It WILL limit how far you can take the high side when running at only 50psi.
