06-09-2023, 03:10 PM | #1 |
Problem with Wi-Fi networks
2022 SS. I went into the system setting the other day and noticed that the Wi-Fi network setting selection was greyed out. I tried with the ignition on and with the engine running. Any idea why this is greyed out and I can not get into the Wi-Fi settings? It used to work, now it doesn’t.
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
07-11-2023, 07:17 AM | #2 |
Drives: 1SS + SS-Sedan M6 + Terrain diesel Join Date: Mar 2019
try app: maybe toggle the wifi in the car off/on/off, saving inbetween? (while antenna has line-of-sight to sky.)
also the onstar people can enable/disable/verify vehicle's wifi setting remotely. let us know what you discover ! nice options/setup on that 2SS. |
07-12-2023, 03:19 PM | #3 |
Sorry for the delayed response. I finally fixed it. I had performed my searches for this issue on the web. Nothing came up. So i took my car to the dealership and after having the car all day they called me to tell me that they can't find anything wrong. Said they called on-star and they were telling them that I need a data subscription for it to work. I told them you don't and that it used to work. Asked if they could keep the car another day. I said sure.
The next day I searched the web again. This time I widened my search by not including Camaro. One hit came up in a Traverse forum and they had the solution. It turns out there is a setting in the mobile app for wi-fi hotspot. If you disable it, which mine was, it also disables the wi-fi network. No where is this documented. I enabled it and 15 minutes later I get a call from the shop saying it is working.
07-12-2023, 03:22 PM | #4 |
Thanks. I really like the 2SS.
