Old 06-09-2023, 08:32 AM   #1
JSH
JSH's Avatar
Drives: '20 ZLE
Fuel/Timing Advance
Which fuel(s) and how much timing advance are you running at WOT?
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 06-09-2023, 10:25 AM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
E50, 23 degrees
Joshinator99 is online now   Reply With Quote
Old 06-09-2023, 10:27 AM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
E75, 25
'20 ZL1 Black "Fury"
Old 06-09-2023, 10:30 AM   #4
Nimair.ZL1
Drives: 2023 Chevy Camaro ZL1
91, 20-21
Nimair.ZL1 is offline   Reply With Quote
Old 06-09-2023, 03:28 PM   #5
JSH
JSH's Avatar
Drives: '20 ZLE
104/25
109/27
2020 ZL1LE A10.
Old 06-09-2023, 03:59 PM   #6
Joshinator99
Moderator
Originally Posted by Nimair.ZL1 View Post
91, 20-21
Feel like there’s a “knock knock” joke in there somewhere..
Old 06-09-2023, 06:23 PM   #7
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
93 + 50/50 Meth ~24°
Old 06-10-2023, 10:00 AM   #8
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
25 is as high as I will take a LT4 even on the highest octane you can find...especially an SBE. Built engine with upgraded thrust bearing, I can see pushing a little harder in certain situations. Imo 2 more degrees for 20whp isn't worth beating the shit out of the rotating assembly for a little more power. I mean Jesus H. Christ private Pyle it's already making almost 1000wtq. And just because it makes a little more power on a dyno doesn't always mean it's in the customers best interest to run it there. dyno numbers and hard street pulls are not equal.
Old 06-10-2023, 10:51 AM   #9
JSH
JSH's Avatar
Drives: '20 ZLE
I hear you. I'll only run the 109 at the track
2020 ZL1LE A10.
Old 06-10-2023, 01:07 PM   #10
laynlo15
Drives: 2022 Lt1 A10
I'm running E65, 18 degrees of timing and 5 degrees of Flex Fuel timing, so 23 total, that's on 11 psi of boost. Now that we know what was causing false knock we will add some more timing next time out, still have plenty of fuel so might go up to E70, not sure if we'll make anymore power, but worth a try since I'm running mainly 1/8 mile till fall we'll set up a pretty aggressive tune. Keeping boost level where it is, loving my pistons.
Old 06-13-2023, 10:47 AM   #11
JSH
JSH's Avatar
Drives: '20 ZLE
We need to meet at Topeka in some good weather, e.g., not 90+F
2020 ZL1LE A10.
Old 06-14-2023, 10:07 AM   #12
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
E60-E70 (sometimes meth too) / between 25-27 peak depending on the car and mods. ZL1's are heavier than Z06's so that comes into play as well. I also have a strategy in place that pulls timing when humidity drops in colder temps and I don't desensitize the MAT multiplier for IAT's. I instead use the Flex Fuel multiplier to adjust a little for ethanol content so it pulls timing at a slower rate vs pump gas for intake temps.
This is my strategy and seems to do well. If I don't know the client I err on the safer side because there is no telling if they will have 4 people in their ZL1 trying to race in Mexico. The heavier the car, the less timing I'm willing to put in it.
Old 06-14-2023, 12:36 PM   #13
Future1LE
Drives: 2020 Chevy Camaro ZL1 1LE
Would all the timing mentioned here apply to a port injection zl1 with stock heads and cam? Mine is a 2650 headers, intake, 103 inlet and TB, E85. Just stock heads and cam. Mine is currently 22* right now.
Future1LE is offline   Reply With Quote
Old 06-14-2023, 01:42 PM   #14
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
Not a ZL1, but 15 degrees at 12 psi on 93. I run Boostane to 96-98 octane for a little extra safety.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
18.2SS.1LE is offline   Reply With Quote
