Old 06-07-2023, 09:37 AM   #1
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Question Trans cooler on LT1
Question for you guys who have a Camaro LT1 A10 without the factory installed trans cooler. Have you installed one? Which one? Location? How about ordering the factory SS trans cooler and mounting it exactly like the SS does, will that work? Talk to me people!
Dynamical is offline   Reply With Quote
Old 06-08-2023, 07:27 PM   #2
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
I believe the 10 speed auto LT1 has the trans oil cooler mounted horizontally behind the front bump cover down low.
lt4camaro is offline   Reply With Quote
Old 06-09-2023, 05:25 AM   #3
Dynamical
Dynamical's Avatar
Have you confirmed this with your car? Everything I have read says the LT1 did NOT come with a trans cooler
Old 06-09-2023, 12:06 PM   #4
lt4camaro
lt4camaro's Avatar
Yes, here is a picture of it. I removed a some of the plastic covers down there so it can be seen. You can also see it with the hood open and looking down thru the hood latch opening.
Old 06-09-2023, 12:08 PM   #5
lt4camaro
lt4camaro's Avatar
I do all my own work on my cars, I set up my cars for the 1/4 mile passes, I will tell you what works etc.
Old 06-09-2023, 08:45 PM   #6
Dynamical
Dynamical's Avatar
Well SOB there it is! I'm almost in disbelief!
What is the RPO code for that cooler do you know?
I looked at an LT1 right here in town yesterday. I looked down through the hood latch and wondered if the plastic down there could be the location for mounting the cooler on the SS. Little did I know at the time, maybe I was staring through the holes of the cooler!
I have the build sheets for the car I looked at yesterday and also another car up in Putnam. I could not find anything on those sheets describing a trans cooler.
Oh, and VERY nice pics thank you! I do all my own work too.
Here's the big old bastard I used on old 4th gen. Summit Racing made it
Old 06-09-2023, 09:01 PM   #7
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Yeah the trans cooling is both in the main radiator plus the lay down cooler in the bottom of the front nose. Transmission cooling was taken seriously by the Camaro team and it’s rock solid in that regard.
Old 06-09-2023, 09:26 PM   #8
Dynamical
Dynamical's Avatar
Did you know the Camaro LT1 came with the trans cooler? I did not. Everywhere I looked said only the SS and up got the trans cooler.
Well I guess if I pick up and LT1 I don’t have to worry about installing a trans cooler. Now my next question lol, does this mean the LT1 also got the cooler lines going to the differential???
Old 06-10-2023, 07:18 AM   #9
lt4camaro
lt4camaro's Avatar
The cooler for the rear end is for the ELSD rear not the standard limited slip. The ELSD is best for road courses, The regular limited slip best for drag racing imo.
Old 06-10-2023, 07:20 AM   #10
Dynamical
Dynamical's Avatar
Thanks and I agree. I didn’t want those extra lines going back there either.
Old 06-10-2023, 07:42 AM   #11
lt4camaro
lt4camaro's Avatar
There is no RPO code for the trans cooler that I can see on my build sheet, maybe because its standard equipment with the 10 speed auto trans.
Old 06-10-2023, 07:43 AM   #12
Joshinator99
Moderator
Negative my friend. Standard SS has the diff cooler lines with regular limited slip diff (only SS/1LE and ZL1 get eLSD).
Old 06-10-2023, 07:51 AM   #13
lt4camaro
lt4camaro's Avatar
Thanks Josh, I learned something today. I always assumed there would be no reason for a cooler on a regular limited slip rear.
Old 06-10-2023, 08:32 AM   #14
Dynamical
Dynamical's Avatar
Well this is interesting. There’s no way to know if every LT1 comes with the trans cooler and I’ve looked like 3 times through this 2023 brochure.
https://www.chevrolet.com/content/da...-ebrochure.pdf
