Old 06-02-2023, 04:30 PM   #1
Jaydoubleyou
Drives: Camaro
Getting new front brakes
I’m an avid reader on here y’all, I have learned so much from this place and have seen a similar post about getting OEM pads installed. My local dealer had said the regular OEM are on national back order. They can get AC Delco that have the same dimensions…. I’m not really comfortable with that off the rip. I daily my car and really love to drive it. I plan to try and track in in NOLA this summer sometime (Not all day). Have y’all had issues with getting OEM pads? And should I have them swap the fluid at the same time? Thanks in advance!
JW
19 ZL1 Mosaic Black, M6 like a dude with all the fixins.
10 SS Aqua Blue (Sold)
93 RX7 475rwhp (Sold) regrets there
Jaydoubleyou is offline   Reply With Quote
Old 06-02-2023, 07:41 PM   #2
Vigilante375
Drives: 2018 Camaro ZL1
Lots of stuff are on "back order". Your can go online yourself and have it in your hands in the next day or 2.
My go to place has always been Amazon as you can find it on there for a good price regularly.
They'll put DOT3 back in the car so if you plan on taking l tracking the car then buy some Motul RBF 600 DOT 4 fluid and make sure they put that in.
Old 06-02-2023, 08:11 PM   #3
NG329
Drives: Chevrolet Camaro ZL1 1LE
JW
OEM pads and rotors are fine. Just swap out the brake fluid with Castrol SRF. If you're new to the track then don't do anything other than show up and ride.
NG329 is offline   Reply With Quote
Old 06-02-2023, 08:45 PM   #4
Jaydoubleyou
Drives: Camaro
They found some brembos that are OEM for over $500 about an hour north. They said it would be $40 extra bucks to get it. I found some after a quick google for $3xx. Follow up question. My fronts were 1mm from changing that backs are good I guess. I read some things about swapping all 4. I seen some different opinions on doing all 4 or just the fronts. Just wanted to pulse the group.
Old 06-02-2023, 09:00 PM   #5
Vigilante375
If the rears are good then don't change them. I would buy a set of rear pads so that when they are ready to be changed, you have them on hand.
By the way, don't ever buy any parts from the dealer. It's always going to be overpriced.
Old 06-03-2023, 09:47 AM   #6
cdb95z28
cdb95z28's Avatar
Rockauto or Amazon for the pads. The OE pad also has an AC Delco #. They are the same pads.
"KEEP THE FAITH"-Fbodfather
Old 06-03-2023, 02:28 PM   #7
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
These show available:
https://www.summitracing.com/parts/ado-171-1192
Old 06-03-2023, 03:22 PM   #8
Vigilante375
Much cheaper on Amazon, as usual....
GM Genuine Parts 171-1192 Front Disc Brake Pad Set https://a.co/d/aTkb4C8
Old 06-03-2023, 04:10 PM   #9
Gunkk
Gunkk's Avatar
Yeah that's a great price.
Old 06-03-2023, 10:25 PM   #10
Camfab
Drives: ‘23 ZL1-1LE
I know pics for parts are usually meaningless, but I couldn’t help but notice the summit pads said Made in Italy, and the Amazon said nothing. They’re probably all China now.
Camfab is offline   Reply With Quote
Old 06-04-2023, 07:28 AM   #11
Vigilante375
Brembo's are only made on Italy. I've order at least 3 sets from Amazon before and there was nothing but Italy written on it.
Old 06-04-2023, 10:38 AM   #12
cdb95z28
cdb95z28's Avatar
Yep, these pads are made in Italy. They are actually made by Ferodo. Another way to verify they are correct is to look for the HP1000 stamping on the backing plate. That is the actual pad material code.
Old 06-06-2023, 10:05 PM   #13
Camfab
Drives: ‘23 ZL1-1LE
Thanks guys! As an fyi Brembo does have a Chinese factory. When it comes time for pads I’ll have to cross that bridge, as I have the copper free brakes which definitely means I don’t have those pads…..
Old 06-06-2023, 10:16 PM   #14
Camfab
Drives: ‘23 ZL1-1LE
I know what you’re saying but over the last 35 years I’ve made it a point to buy everything from my dealer. They know me as a loyal customer and extend me the same pricing the local shops get. Having the dealer in your back pocket has gotten me parts and leads that are priceless. This is especially true if you have older cars that benefit from the brain of a seasoned parts guy. It doesn’t stop me from checking pricing on the net.
On the flip side, I have zero allegiance to the sales dept as the dealership has changed hands multiple times, but the parts manager is still there.
