![]() Drives: 2022 camaro 2SS Join Date: Apr 2023
coolant temps
whats the normal coolant temp for these cars?
i never really looked at the digital gauge till today and when i was idling waiting for food i noticed the temp was at 208 degree's. is this normal? |
Mine stays at 195-ish if I remember correctly, the digital gauge only shows an approximation anyway.
208 degrees at idle, assuming outside temperature wasn't something crazy like 130+, is definitely not normal and indicates a problem. Check your coolant levels first, and if low, check hoses, the oil dipstick, white smoke coming out of the exhaust pipes, the usual suspects.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 Last edited by arpad_m; 06-03-2023 at 12:53 PM. Reason: typo |
#3 | |
![]() ![]() Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I get to about 212 on the track.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Behind someone? Eating their exhaust, closed in space, hot asphalt, ambient, etc... could be "normal"
For some reason I thought 212-215 was full open?
<Insert Cars You Own Here>
#6 | |
2020 Shadow Gray 2SS
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (455 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#7 |
was after a 40 mile drive home mostly interstate. the temp gauge on the dash looked about normal but i was messing with all the digital gauges since i was sitting at Sonic waiting for my food and it was showing 208
#8 |
this was after a drive today and letting it idle for a couple minutes at home to see what it does. looking at the gauge on the dash it dont seem hot but the digital one does.
starting to wonder if the digital one is not reading right. it was only 83 degree's today |
#9 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Are the fans running? A/C on? If no, do fans run with A/C on?
#10 |
fans were moving but not very fast and they were quite couldnt hear them
#11 |
![]() ![]() Drives: 2021 300 Join Date: Jan 2015
208 is in normal range, fan sensors are not all the same some come on early some late.
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Seems normal to me! In my honest opinion you don’t have an issue with your Camaro.
#14 |
Yeah, I probably should have remained quiet, my car isn't stock. BTW by "digital gauge" I meant the gauge in the cluster screen, not the numeric temperature display (that my 2018 doesn't have anyway).
