Old 05-31-2023, 05:45 PM   #1
collinms
Drives: 2017 ZL1 A10 Summit White
Fuel pump failure
29k miles. 2017 zl1. So now I've had an oil pump and fuel pump failure... Good times.
collinms is offline   Reply With Quote
Old 06-01-2023, 04:02 PM   #2
BunnyBoy
Drives: 2017 ZL1
HOw did you know it was going out?
BunnyBoy is offline   Reply With Quote
Old 06-01-2023, 04:21 PM   #3
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
He probably noticed it when he lost fuel pressure...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 06-01-2023, 11:15 PM   #4
collinms
Nope died on me driving down the road. No warning. No time to even pull off the road. It was bad, not going to lie. 3 hours to get a tow. Flagging cars to warn them because nobody plays attention anymore. Someone came within inches of hitting my car. Looking like around 2k to replace, I'll update when I pick up the car.
Old 06-02-2023, 06:17 AM   #5
BunnyBoy
Drives: 2017 ZL1
Any weird things you noticed happened before it went out?
Old 06-02-2023, 09:30 AM   #6
L78toLT1
L78toLT1's Avatar
Did you lose the high or low side pump?
Baby Blue
Old 06-02-2023, 10:54 AM   #7
Camfab
Drives: ‘23 ZL1-1LE
Just to satisfy my curiosity, have you ever used any fuel other than premium unleaded? Any additives, higher ethanol content fuels?
Camfab is offline   Reply With Quote
Old 06-02-2023, 10:58 AM   #8
ctrlz
For $2k it better be the high pressure pump!
The important thing here is to do some failure analysis on the old unit, which probably will not happen.
Old 06-02-2023, 01:04 PM   #9
collinms
No warning, no noises prior, just 93 fuel, no additives. Here are the part numbers:23382215,19209796,85170844. $1866. I guess Install is bad on it, says they had to remove exhaust and driveshaft to gain access. Looks like that was the majority of the cost.
