![]() Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
Negative Torque tables at Idle??
dyno1.pdf
dyno2.pdf Hey Guys, thought I'd post my numbers after the blower/cam install. The previous number of 808hp came from a Mustang. On another note, I have noticed that the car has been idling high - 700 commanded, ~860 indicated. I brought this up to the dyno guy and he said he noticed it. He also said the torque tables at idle were showing a negative value, and that might have something to do with the high idle. Or, maybe a small vacuum leak. No CEL showing. I would be grateful for any thoughts before I sign an open check to fix the problem.
JRE Terminator Rough Idle Cam
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 Last edited by MartinLe; 06-01-2023 at 12:56 PM. Reason: change header |
![]() Drives: ‘23 ZL1-1LE Join Date: Mar 2023
Nice numbers!
#3 | |
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#4 | |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
#5 | |
Magnuson 2650 - 15% lower, 90mm upper FIC+30% DSX Flex fuel/Low side NW 103mm TB/Roto-Fab CAI Monster S Series Elite E2-X 2" TSP LT's BMR:BK063, BK060,TCA061, UTCA060, UTCA063 Weld Beadlocks/17" NT5R2 |
