05-31-2023, 06:09 AM | #1 |
Drives: '16 2SS A8 Join Date: May 2023
Wireless Charging Pad
Recently purchased a '16 2SS that has the wireless charging pad behind the center console. I would very much like to take advantage of this feature, but I've discovered that my phone is around a half inch too tall to lay flat on the pad due to the little protrusions that I assume are meant to keep smaller phones secure. Anyone find/make a fix for this?
05-31-2023, 07:45 AM | #2 |
Drives: Camaro Fifty Join Date: Sep 2018
There are some solutions inside the forum:
1.Getting rid of the rubber pad inside the charging bay 2.Cutting of the edges of the rubber pad 3.Buying the 2nd generation wireless charger from GM --> part price around 100 USD 4.Buying a dedicated wireless charger and put in on top of the wireless charging bay Try solution 1. If this does not work, you don't need solution 2. For solution 3, you can google the official compatibility list of the wireless charger. I personally had the same problem and bough a dedicated charger. I bought the ESR wireless charger with cooling fan. As I use Android Auto wireless, the phone's battery consumption is pretty high. With wireless charging you will get very high battery temperatures, which will kill your smartphone battery pretty fast. Therefore I went with the cooled wireless charger. I made a hole inside my phone case and added a magnetic ring so that the phone sits really tight when being charged. Please find my solution here: https://www.camaro2010.de/t18319f158...html#msg674966 (I hope it is ok to add the links of the german Camaro forum over here) Last edited by SOFO; 05-31-2023 at 07:48 AM. Reason: Link added |
05-31-2023, 09:01 AM | #3 | |
Drives: 17 camaro ss Join Date: Mar 2018
You link is gone. They must have taken it down. |
06-01-2023, 01:23 AM | #4 |
I added my pictures in this thread.
06-30-2023, 03:19 AM | #5 |
Drives: Hyper Blue Metallic 2017 Camaro 2SS Join Date: Jul 2015
Since you have a 2016, there is another issue with the wireless charging pad. For some reason, the Chevy engineers designed this pad to very specifically fit a Samsung (I think) phone from ~2015. The problem is that both phone and wireless charging technology has changed a lot since then. The first issue is the one you described: phones are bigger than ever (most won't even fit on the pad). The second issue is less apparent. The original wireless charging pad used an older standard that has less electrical coils than modern devices require. Sometime around the 2018-2019 model years, GM changed the wireless charging system from "GEN I" to "GEN II". For those of us with older cars, GM made an upgrade kit (see TSB 18-NA-153). I have an iPhone 11 Pro Max, so there is no way that I can fit my phone in the tiny space Chevy gave us. However since CarPlay requires my phone to be plugged in, I never feel like I'm missing out. The space is also very inconvenient to reach with the stock SS seats, and I can only imagine how difficult it is with the Recaros. All that being said, I do use the wireless charging pad from time to time to charge my AirPods. Even with spirited driving, the rubber mat seems to do a good job at holding them in place. I hope this helps!
2017 Camaro 2SS Hyper Blue Metallic
8-Speed Auto, Magnetic Ride Control, Borla S-Type Exhaust (NPP), HRE FF10s (Tarmac), Michelin PS4S Tires, Rotofab CAI, SEMA Grille, Mishimoto Oil Catch Can, StopTech Slotted Rotors, PowerStop Z26 Pads Also Own: - 2004 Lexus RX330 |
