Old 05-28-2023, 07:01 AM   #1
cjperformance
cjperformance's Avatar
What crank pulley to use with Procharger and ATI balancer?
Looking at using an ATI balancer instead of the stock one, but having trouble figuring out what crank pulley i can use with my P1X. I'm concerned with offsets and alignment and not so much the diameter.
Any suggestions? Theres lots of "supercharger crank pulleys", but nothing that seems specifically geared towards aftermarket balancer and procharger.
Some specific part numbers would be great if you've already made the switch.
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 05-28-2023, 08:09 AM   #2
Kerry
Drives: 2019 2SS Camaro
Contact Bob beam at brute speed. Their are only 2 options with procharger and ati balancer. 8 rib and 10 rib. They are both 8.25. U just bolt them on and alignment is supposed to be the same as stock balancer and the pulley that comes in the kit. I run the 10 rib with 8 rib belt and upper pulley lol. Tring to decide on my upper size to go 10 on it
Kerry is offline   Reply With Quote
Old 05-28-2023, 08:15 AM   #3
laynlo15
Drives: 2022 Lt1 A10
I run a toohighpsi 10 rib with 9.25 lower for my Maggie 2300.
Old 05-28-2023, 02:32 PM   #4
Kerry
Those wont work with procharger way out of line. I wish lol
Old 05-28-2023, 06:06 PM   #5
laynlo15
Gotcha, didn't know that.
