![]() Drives: ‘18 ZL1 / ‘22 ZLE Join Date: Oct 2013
Lift block bending during lift
Hi all,
I just did my first oil change and it was a bit sketchy. I lifted the car up from the zl1addon blocks and I noticed the block was bending towards the door as the car was being lifted. I can’t center the lift point on my Daytona Jack with the lift pad so I have to use the putter portion of Jack to lift. If I go from the center the Jack ends up hitting the side skirt. If I put a block of wood in there I feel like it will slip. What are you guys using? |
![]() Drives: 2018 Hyper Blue Camaro 1SS Join Date: Sep 2019
I just use ramps. I never lift the car for an oil change.
1LE Replicas / Solo Axleback Exhaust/ Street Scene Front Splitter / Diode Dynamics Smoked LED Side Markers / OEM Smoked Tails & Third Brake Light / OEM Illuminated Door Sills / OEM ZL1 Side Skirts / OEM ZL1 Spoiler / OEM Black Badges / GM CAI / Soler Engineering TB/TC / Katzkin Leather / 20% Tint
![]() Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
Are you sure the jack pads are fully bottomed out on the pinch rail? I’ve never had any problems lifting with them. Maybe you should double check that.
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
I agree with making sure the pads are fully seated in the pinch rail.
I've used mine for years taking the tires on and off and never had a problem. What I do is lay down and slowly raise the jack to the pad but roll it back and forth so I can center the lift point with the jack then start to raise the car after that. |
#5 | |
![]() Drives: 2023 ZL1 M6 Sharkskin Join Date: Nov 2020
2019 Porsche 911-T M6-SOLD
2020 Crush ZLE A10-SOLD 2023 Red Hot ZLE M6 ordered 5/9/23, never built 2022 Shadow Grey 1SS-1LE M6-SOLD 2023 Sharkskin regular ZL1 M6-SOLD |
Thank you all for your responses. It was a rookie mistake on my behalf. Lifting these cars on pavement is never a good idea. My Jack was never moving forward as the car was being jacked up causing the pad to push towards the car. I tried it on the concrete floor and the pad stayed in the same position the whole time while the while wheels moved forward
