![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Supercharger Manual Question
Does HP tables regulate the boost power levels in gear selection?
Looking for a way to regulate power in 1,2, and 3 gear. Basically at this point the increase power levels are roasting my tires off. My previous set up on my Nitrous setup I was able to ramp in the percentage at RPM levels to avoid spinning. What are you guys doing for this? Is it something that the tuner needs to address at the track?
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
Ok was talking to tuner and how much the car spun in gears. No boost control thru gears. So that issue is dead.
He did mention, “Better to drive traction control off as torque management gets confused.” I was trying it with traction control on, and it was all over the place. So tomorrow I will try traction control off.
![]() Drives: 2015 Z/28 #397 2022 ZL1 #1799 Join Date: Jul 2009
Hopefully you can find a way to keep it going straight! I had seen your post yesterday and thought that was probably the case with no boost control per gear built into the car. Isn't this what JOSHINATOR is doing with his Whipple 3.0? Smoothboost??.
Thanks for post and I don’t think it’s exactly what I am looking for. My problem it’s what that mod fixes, my supercharger hits instantly and lots of power but I would like to tame it down in the lower gears and able to ramp it in. It does not appear to be anything like that available. Wishful thinking on my part. Fresh new tires are the only answer I see currently.
There is no built-in boost control with PD superchargers, pulley sizes determine their rpm (thus boost) and the bypass valve is an on/off affair.
Smoothboost would mostly solve this problem [of you wanting a PD behave like a Procharger, heh], not sure why you're saying it isn't exactly what you're looking for. Is it that it's driven off the throttle position signal and doesn't reference the current gear?
#6 | |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 2SS A8 Join Date: Aug 2018
Another option is to pull timing in the areas where you don’t need the extra torque. I pull timing from 2500-5000 RPM to help prevent the tires from getting blown off.
#8 |
I love that this is the solution. lol. "It's so powerful, I actually need to it make LESS power certain times."
#9 |
![]() Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Dumb question but what is your wheel/tire setup ?
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
#10 |
Not dumb, the tires were worn so didn’t help. Waiting for new Nittos to show up.
Rear NT555RII P305/45R17 Front NT555 G2 245/40ZR18
#11 | |
#12 |
![]() Drives: 2015 C7 Z06 M7 Join Date: Dec 2012
The timing method as Josh outlined normally works very well, it will take a couple hits to get it dialed in at the track but very effective when done correctly, especially with a stock torque converter as that lower RPM area will only be touched at launch in 1st (or 2nd if you're leaving in second).
#13 |
![]() Drives: 14 Camaro SS 1LE Join Date: Feb 2019
There are ways to do it on the LT4's, that is why they have a dual port bypass valve. If i remember correctly, factory PTM regulates boost to help with wheel spin conditions.
Haven't looked into it too much though. |
#14 |
Didn’t the earlier Gen6 ZL1 have the electronic bypass valve and then they switch to the vacuum lines? I thought I heard something like that or I could be wrong.
