05-18-2023, 08:26 AM | #1 |
Drives: 2018 ss Join Date: May 2018
LGX compression
my 2023 v6 LGX says it has 11:5 compression ratio yet still recommends 87 octane gas. How can that be?
05-19-2023, 09:39 AM | #2 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
I used 87 from new to 18 k miles. It smelled when I ran it hard and made some stranger noises sometimes.I thought I had an exhaust leak. So I changed to 93 at 18 k miles,now at 5Ok miles. No more exhaust smell or bad sounds, runs stronger, better. I guess it pulls timing for 87. Some say 93 is a waste but it is all I use in my v6. Some reputable tuners recommend 93 for the lgx. My experience is it will run on 87.It will be happier and run better on 93.
B6 dampers, x pipe, mbrp axel back
05-19-2023, 10:39 PM | #3 |
Drives: 2020 3LT Camaro 3.6L 1LE Join Date: Feb 2020
05-25-2023, 05:20 PM | #4 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Never had an issue running 87 even at the track. No timing knocks or funny smells and great gas milage. Putting high octane is like taking a sugar pill it really does nothing for the LGX except waste your money. It's a fact that higher octane fuel doesn't create more energy it increase the resistance to knock. Gm engineers recommend 87 for the 3.6 and 91 for 2.0 and 6.2, but what do engineers know right.
05-25-2023, 08:46 PM | #5 | |
Drives: 2022 1LT RS 2.0t/6spd Join Date: Mar 2022
I ran into a guy gassing up a 1994 454 motorhome the other day. He was putting 91 into it and was not happy he couldn't find 93 in the SW. Insisted premium was necessary because of how "hard" his engine had to work. Those engines had such low compression and output (I owned one) that they would probably run fine on kerosene. But you can't keep some people from wasting their money. |
