05-08-2023, 07:59 AM | #1 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2019
305 square vs staggered issues
I have a 2018 and I decided to run 305 square on 19s this year for autocross. With the ice mode issue ive lost some confidence on the brakes and it is consistently losing me time.
Does anybody know if throwing a 315 or 325 on the rears will help or even eliminate ice mode being a constant issue. I know there are a lot of threads on ice mode but I could not find a definitive answer. |
05-08-2023, 01:20 PM | #2 | |
Ice mode usually means too much brake for the tire. What pads will you be running and can you get any heat in them during autocross?
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
05-08-2023, 02:46 PM | #3 |
Im running stock pads with rt660s at autocross. I ran the OEM wheel/tire setup the last 2 years at autocross and currently run that as my track day setup. Never any issues with the OEM setup
With the rt660 setup on occasion the car just refuses to brake and plows on at autocross |
05-08-2023, 02:52 PM | #4 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I have a 2022(which is supposedly not affected by ice mode, or at least less so) and I do get a weird issue when using slicks or sometimes randomly even on OEM tires. I believe it's related to ice mode but I'm still confused on it.
I basically randomly get a hard pedal and it just feels like the car will not stop, but it does. It's a hard pedal followed by what feels like no initial bite. I got it quite a few times running new R7 hoosier slicks on the track this weekend 315/30/18. I got used to it after a while but it's not cool how it just randomly happens. Luckily it only seems to increase my braking distance by a couple feet so it's not the end of the world, I do miss the apex though. Could be pad related as well, but I'm not sure. I didn't see any correlation between overheating or not. In fact it felt like it would do it more often following a long straight where the brakes had more time to cool. Running DTC 60's. |
05-08-2023, 03:28 PM | #5 |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
I went back to staggered (315/30/19 and 305/30/19 RT660 on ZLE sized wheels) bc of ice mode, it should help a lot because it's caused by both side to side as well as front/rear wheel speed discrepancies. So the ABS is used to seeing the fronts turn faster than the rears. I know some Vette drivers that gave up on square for the same reason, it makes ice mode MUCH more likely.
You can also upgrade to a '19+ EBCM (Electronic Brake Control Module) which is FAR better. A lot less ice mode and if it does happen it's like @Christian1LE said, it's momentary, pre-'19 it was FAR more than just momentary. I've only got it once since installing the '19+ EBCM and going back to staggered, it extended braking distance maybe 10 ft or so if that. I started a thread on my EBCM swap and it's also in the AutoX thread. You need to find a donor car with the exact same options as your car or there will be issues if not a bricked car. Check the VIN. After the swap the car may need to reset a bunch of stuff, I had to drive it around the block before error lights went away. Good news is I got the parts for <$100 on ebay, they generally come with the ABS pump but you don't need to change that out, only the electronic module attached to it. It's a bit of a PITA to get to, so maybe 45 min or so of time. I may have lost teen driving mode and controls for the '19+ rear-view camera came up on the screen, so there may be some minor issues but the '19+ ABS software is a major upgrade. Also, you can't buy one new, it's $$$ and they come unprogrammed, so if you get a new one you also need a '19+ car to install it into and flash the programming, so just look on ebay and in junkyards. For '17-'18 SS 1LE I'd consider the EBCM, ZLE rear subframe bushings, SPL rear toe arms, a stiffer front bar (Hotchkis) and Vorshlag camber plates as the first things do to if driving on track or autox. It'll make an already great car even better.
05-08-2023, 03:33 PM | #6 | |
05-08-2023, 07:27 PM | #7 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Ice mode happened more often on my 100 treadwear 3R tires on ZLE wheels compared to stock wheels/tires at MSRH but I haven't yet tested with them since I did the EBCM swap. I expect a big improvement even if ice mode isn't completely gone on the 3Rs. Here are the steps for the EBCM swap. Unlike DaveC, my car didn't have any lights or issues and started right up afterwards, maybe because I pulled the ABS pump fuse before starting: https://www.camaro6.com/forums/showt...0#post11248660 |
05-08-2023, 07:34 PM | #8 | |
05-08-2023, 09:20 PM | #9 | |
This thread reminded me that I made a before/after ice mode comparison video from my Harris Hill PDR videos last year but never uploaded it. Here it is:
I could make another video for MSR Houston clockwise too since I finally drove there again last month and had no ice mode issues after going off into the grass after the launch on my previous 2 visits before the EBCM swap due to ice mode but I doubt I will get around to making that video anytime soon. |
05-08-2023, 11:05 PM | #10 |
Thanks for all the info. I will research the ECBM swap but is it not difficult to find one with all the right options of my car? If I can do that switch without new tires and wheels that would be great. I just bought this setup in the winter.
05-09-2023, 08:18 AM | #11 |
I have been searching ECBMs on ebay and there are a ton but I do not know how to differentiate what options the car had. Do i just need to find a part listing that lists all the options of the vehicle it came out of?
05-09-2023, 08:50 AM | #12 | |
If neither the VIN or exact car w/options are listed try contacting the seller for the info.
05-09-2023, 09:20 AM | #13 |
Drives: 2020 ZL1 A10; Shadow Gray Metallic Join Date: Sep 2020
Has anyone had any issues with running tires that are the same height and PTM modes? I typically run Pirelli 305/660 F 325/680 R, but 325/680s are getting increasingly rare. I could run 305/660 F 325/660 R, but not sure if that would mess up electronics. 315/680 R is also an option, but I prefer the wider tire.
05-09-2023, 09:56 AM | #14 |
Thanks Dave, I have been down a rabbit hole of vin numbers today.
When you say options, does it have to be color as well? I found a part off of a 1SS 1LE, just like mine. Except my car is black and the part came off a car with that gorgeous red paint. Will that work or do I need to find a black car? |
