Old 05-07-2023, 11:19 AM   #1
NG329
Drives: Chevrolet Camaro ZL1 1LE
Installed a Powertex Lithium Battery
I grabbed one of these for 499 and so far I'm very pleased. The car seems a bit peppier too.
If anyone has questions please feel free to ask here.
NG329 is offline   Reply With Quote
Old 05-07-2023, 09:10 PM   #2
george
ZL1 Driver
george's Avatar
Drives: Camaro ZL1 & BMW M3/E92
Where did you buy it? Is it made in the USA?
george is offline   Reply With Quote
Old 05-07-2023, 09:20 PM   #3
NG329
I bought it direct from PowerTex’s website.
It’s an American company but the battery is Made in China.
Old 05-07-2023, 09:24 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
$499 is damn cheap for a 60 Ah battery!
Old 05-07-2023, 09:56 PM   #5
Sillysspeed
Drives: 22 LT1
Nice to have some other options and less $$$ too
Sillysspeed is offline   Reply With Quote
Old 05-07-2023, 10:24 PM   #6
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
The weight reduction is impressive and the CCA as well. Should turn over quicker.
Revalot is offline   Reply With Quote
Old 05-07-2023, 11:38 PM   #7
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
Hopefully "Made in China" doesn't mean "burst into flames in your garage and burn your entire house down"... No idea what a "Lithium Iron Sulfate" battery is, but I hope it is nothing close to a "Lithium Ion" battery...
2SS Capt is online now   Reply With Quote
Old 05-08-2023, 01:18 AM   #8
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
Lithium Iron Phosphate (C/LiFePO4) is what this battery is, and is indeed still a lithium ion battery. The variation in the chemistry makes the voltage profile more like that of lead acid and also allows it to have a high rate capability (C rate) aka 'can discharge a lot of current.' This battery does NOT like to be charged below 0°C and if done will cause dendrites which can penetrate the cell separator and cause a catastrophic failure. Also at high temperature, above 45°C this battery will NOT want to be charged either and might even go into 'open circuit' condition to protect itself.....
Schlok is offline   Reply With Quote
Old 05-08-2023, 01:22 AM   #9
JBones81
Drives: 22 ZL1, 18 RS3, 22 M3P
how does this make the car feel more peppy?
Are there downsides to running a lightweight battery in our cars, besides the price?
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2024 Audi RS3
2022 Tesla Model 3 Performance
2018 Audi RS3 - Many mods & e85
Instagram - @JBsCars
JBones81 is offline   Reply With Quote
Old 05-08-2023, 05:24 AM   #10
Z OH 6
Drives: 2024 CT5-V Blackwing
Less weight.
No.
Old 05-08-2023, 08:08 AM   #11
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Great information about the temperature characteristics.
It sounds like this might not be a good battery for a daily driver in some climates.
Old 05-08-2023, 08:12 AM   #12
NG329
Per the pamphlet that came with the battery:
"The rated voltage of the product is about 0.8V higher than that of lead-acid battery, and the discharge power is higher. It can effectively improve the combustion efficiency of the fuel in the engine cylinder when it is used in the car with rechargeable battery as its working power of the ignition system. So when you use this product, you may feel that the car starts faster, the throttle is lighter, the engine is more responsive, the power is stronger, and the fuel consumption is lower, which is normal."
I don't know how true that statement is but I am able to feel a difference since installing.
Old 05-08-2023, 09:17 AM   #13
Z OH 6
Pure marketing nonsense.
Old 05-08-2023, 10:48 AM   #14
NG329
Thanks for this info.
I think we can all be of the general consensus that this is a Spring thru Fall battery and should be pulled for the winters. Honestly, I don't see why anyone who isn't tracking or racing where tenths matter would want to run one of these. And it's really not a modification that anyone can see.
