Old 05-07-2023, 02:38 AM   #1
Mr_Beekay
Drives: ZL1 1LE
Wheel setup - A10 ZL1 1LE
Hey there, I have finally received my 2022 ZLE, which is vivid metallic orange in color. It’s a “new to me” kind of car with close to 4,000 KM and had it imported to UAE from the USA.
The rear tires did not pass inspection test and I had to switch over to what was readily available - 355/30/19 Kumho’s. Now, the car did pass inspection but I did not have a chance to look at the car in person with them. It would only be by tomorrow. The front remains the same at 305/30/19.
My question is, is there anything to look out for with such meaty tires on stock rims? I do understand that the wiring harness might not like it. But i would not be tracking the car, just spirited driving on the mountains and also non-spirited city driving.
Any suggestions are welcome and apologies if this is a repeated query. The search functions seems to not like me.
Mr_Beekay is offline   Reply With Quote
Old 05-07-2023, 09:07 AM   #2
419bobw
Drives: 2017 chevy zl1,1968 camaro turbos
WHY THE 19" WHEELS? IS IT A 1LE? ANYWAY I'VE A 2017 ZL1 305/30/20 BACK,285/30/20 FRONT, YOU USALLY DON'T HAVE CLEARENCE ISSUES WITH AS STOCK
TIRES AND RIMS,ONLY WHEN ENLARGING WIDTH, ESPECIALLY WITH A 35 ASPECT RATIO.
TAKE THE DRIVERS SIDE BACK TIRE OFF AND CHECK FOR WIRES INSIDE WHEELWELL. IF SO, TAKE A FEW FENDER LINER SCREWS OUT AND REPOSITION IT UNDERNEATH THE LINER. I DON'T KNOW IF CARS NEWER THAN MINE EVEN HAVE THEM EXPOSED. I'M GOING WITH 325/30/20 IN THE REAR.SHOULD NOT RUB, BUT IF IT DOES 15 MINUTES AND A 1/4" DRIVE SOCKET AND ITS GOOD TO GO ON STOCK RIMS.
419bobw is offline   Reply With Quote
Old 05-07-2023, 05:07 PM   #3
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2024 Z06
Originally Posted by 419bobw View Post
WHY THE 19" WHEELS? IS IT A 1LE?.
Yeah, kinda was in the title…….
1997 Z28 Anniversary Edition SOLD
2004 GTO ORDER CANCELLED
2004 CTS-V SOLD
2005 CTS-V SOLD
2006 300C SRT-8 SOLD
2010 CTS-V SOLD
2012 CTS-V coupe SOLD
2013 ZL1 vert SOLD
2016 Callaway Z06 SOLD
2019 Z06 SOLD
2021 ZL1 1LE SOLD
cvp33 is offline   Reply With Quote
Old 05-08-2023, 12:17 AM   #4
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
If you aren’t tracking it I think you’ll be ok, other than wiring harness you may need to get a good alignment to make sure you have adequate clearance. I know there was a guy with a ZLE running those 355/30/19 Viper Kumhos and he tried them on track and said grip was better than GY 3Rs. But then he noticed rubbing and I think he stopped tracking on them.
SFV1LE is offline   Reply With Quote
Old 05-08-2023, 07:31 AM   #5
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2024 Z06
Gotta believe that the track alignment and lowering would cause some interference as already stated. But in street trim, my bet is you’re fine.
2004 CTS-V SOLD
2005 CTS-V SOLD
2010 CTS-V SOLD
2013 ZL1 vert SOLD
2019 Z06 SOLD
2021 ZL1 1LE SOLD
Old 05-09-2023, 03:43 AM   #6
Mr_Beekay
Drives: ZL1 1LE
Sorry, what do you mean "street trim"? I'm new to Camaros, unfortunately.
Do you mean switching up the suspension?
Old 05-09-2023, 11:25 AM   #7
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2024 Z06
For the track I lowered my shocks by 1.5” and have 2* camber front/rear. I run stock sizes so no issue. If you run that rear and dial in camber you may have an issue? Just not sure.
2004 CTS-V SOLD
2005 CTS-V SOLD
2010 CTS-V SOLD
2013 ZL1 vert SOLD
2019 Z06 SOLD
2021 ZL1 1LE SOLD
