05-04-2023, 03:48 PM | #1 |
Drives: camaro 2.0 Join Date: Jan 2021
NEW ZL1 OWNER 2013 Question
Hello guys i just recently purchase a 2013 Zl1 over a 6th gen ss I was just more Pleased with the zl1 over the SS. it was really hard trying to find one Stock or without high mileage in my area but i decided to with this one i found with 9k miles on it, it has a few Mods on it and i wanted to show you guys just to see if anything i should be Looking for snice its already modded Thanks.
05-06-2023, 09:37 PM | #2 |
Drives: 2014 ZL1 Join Date: Jun 2009
Just from the pics I see it's upper and lower pulley swapped, long tubes, 5 in intake, catch can, aux fuel system of some sort, flex fuel sensor and aftermarket exhaust.
I would see if it has an aftermarket heat exchanger and take it to a tuner to see what the tune looks like. I'd also want to know what kind of fuel injectors or at least their duty cycle is and the AFR.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
05-06-2023, 09:46 PM | #3 |
I'd say you did good buying that over a 6th gen SS.
05-06-2023, 09:48 PM | #4 |
Looks like it has an AEM methanol kit on it too.
05-07-2023, 06:53 AM | #5 |
Drives: 2013 zl1 vert Join Date: Dec 2018
looks like it was built by RPM. Thier fuel system, intake, and he also uses the aem meth controller. send him the vin and see when the car was tuned or built there.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
Tags |
2013 zl1, 5thgeneration, mods, zl1 |
