Old 05-01-2023, 02:15 PM   #1
JBinSD
Drives: '23 LT Vert M6'16 Hyper 2SS Vert MT
LT1 Replace Rears only?
So I recently leased an LT-1. I had to have a V-8, manual drop top. I do miss the eletronics of the 2SS I previously owned, but didn't really consider the 245s. Since it is a short lease, I am considering buying some SS rears to get more meat out back. Has anyone left the stock (245's) up front and gone to 285 or wider in back?
the stock silver rivers don't offend me, and I think I should be able to find some 9.5" SS rears on the cheap?
Cheers.
JBinSD is offline   Reply With Quote
Old 05-01-2023, 06:29 PM   #2
SHessler
SHessler's Avatar
Drives: 2021 1SS 1LE [Shock]
Keep the tire heights similar and you will be fine.
I admit it, I like Mustangs.
Ex Spec Miata driver.
SHessler is offline   Reply With Quote
Old 05-01-2023, 09:26 PM   #3
...but make sure you get the car off the ceiling safely first
Old 05-04-2023, 06:36 PM   #4
Plasar
Drives: 2017 ZL1 Vert M6
Yes, you have bigger problems - your car is LEVITATING!!!
Plasar is offline   Reply With Quote
Old 05-04-2023, 06:39 PM   #5
JBinSD
yeah, I have been on this forum for seven years and have never been able to fix the inverted pics. I promise these pictures were not upside down when posted.
If anyone has the silver stock SS rears for sale, hit me up :-).
Old 05-04-2023, 06:48 PM   #6
First they have to hit you down
Okay, okay, I'm done You can save the pictures and rotate them back and forth in some photo editor, that'll fix the orientation. The reason they show up inverted is that there is extra orientation metadata in the file that isn't supported by all software, certainly not this 15-year-old forum engine, and it displays the raw data as-is.
Old 05-05-2023, 10:50 AM   #7
JimGnitecki
Drives: Chevrolet Camaro LT1
JBinSD: I bought a brand new 2022 LT1 and had a Magnuson supercharger kit installed by Davenport Motorsports, the Canadian distributor. That resulted in the OEM LT1 rear tires losing traction at full throttle at any speed up to the maximum I have driven the car (about 85 mph).
But i LOVE the optional black forged wheels that came on my LT1. They are the first car wheels I have ever owned that look really good while enabling washing even the inside surfaces when washing the car, and doing so quickly and easily.
But a pair of wider ones for the rear from GM would cost a fortune here in Canada.
Guys here on the forum suggested I try a pair of Nitto 555R2 tires ("street drag radials"), in 275 width, on the 8.5" wide wheels I have. This is technically on or past the recommended limit of wodth on an 8.5" wheel, but the local tire shop manager was comfortable with the safety of it.
That totally solved the full throttle traction problem, at sensible ambient temperatures (the car still loses traction in colder weather, but not nearly as badly).
The appearance of course is also nicer.
Jim G
JimGnitecki is offline   Reply With Quote
Old 05-12-2023, 01:33 PM   #8
JBinSD
Jim G
Thanks Jim, so you went 275 on the stock 8.5" rims without issues? I may have to try that as well. I had the Nitto 555's on my SS for a while; good grip but fast-wearing. I should probably change all 4 tires if I go with different compounds; the all-seasons on the LT-1 do pretty much suck, and I live in SoCal so summer-only is the way to go.
Cheers.
Old 05-12-2023, 01:51 PM   #9
JimGnitecki
Cheers.
JBinSD, my Camaro is not a daily driver, so the notably reduced tread life of the 555R2s versus more normal street tires is not an issue for me. But, yes, if this was my daily driver, I would be concerned about tread life, and would probably have gone to wider rear wheels and tires with longer tread life AND also the ability to handle cold temperatures (We get to minus 25F here in the winter! I don't want to drive the Camaro on snowy and salt laden roads, so it sees very few miles in the winter and only on roads that are free of any salt or moisture ).
Jim G
