Old 05-01-2023, 03:12 PM   #1
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
How-To: Blackwing Brake Cooling Ducts
Did a quick video on the Blackwing Ducts. All of the part numbers are in the video description as well.
23385146 - Front Left Mini Dust Shield
23385147 - Front Right Mini Dust Shield
85536980 - Front Right BW Brake Cooler
85536981 - Front Left BW Brake Cooler
84946132 - Rear Right BW Brake Cooler
84946131 - Rear Left BW Brake Cooler
84946133 - Rear Thread Insert for Screws
85004630 - Rear Trailing Arm (FE4/FEA)
85523690 - Rear Cooling Kit
11548166 - Screws x6
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 05-04-2023, 07:37 AM   #2
Briland_1LE
Briland_1LE's Avatar
Drives: 2020 Camaro SS 1LE
could you post the part numbers ive been struggling to even find them online for sale?
Briland_1LE is offline   Reply With Quote
Old 05-04-2023, 09:18 AM   #3
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Here you go:
85536980 Front Right Brake Duct
85536981 Front Left Brake Duct
84946132 Rear Right Brake Duct
84946131 Rear Left Brake Duct
SSEssence is offline   Reply With Quote
Old 05-04-2023, 09:19 AM   #4
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
OK Part numbers for FRONT brake ducts are :
85536980
85536981
The reason you are struggling is that they HAVE BEEN on national back order for quite some time. If you order some from your local GM dealer be sure to provide him with the VIN number of a Cadillac Black Wing because GM fills those order FIRST before they fill orders for NON BLACK WING owners.
Just go to a dealership ad for a black wing and use that VIN.
It took me about 6 weeks to get mine but after I provided a VIN they filled that order within two weeks.
GOOD VIDEO FollowMyLine!!! We need to tell the boys and girls NOT to overtighten those three bolts that hold these on because you can break the heads off them pretty easily I found out (LOL). I DO NOT have magnetic ride but there was a wheel speed sensor wire that was touching up against the bigger black wing brake duct so I protected it with some split plastic conduit so that it wouldnt chaffe.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 05-04-2023, 10:36 AM   #5
FollowMyLine
Driver for Hire
Here are the mini dust shields for the SS cars;
Luan Zeqollari
YouTube Channel
Old 05-04-2023, 11:03 AM   #6
ColeD
ColeD's Avatar
Drives: Chevy Camaro
Are these a replacement to match up with the blackwings scoop or an addition?
Also I can't find the brake ducts on rock auto im guessing it has to be from gm huh. These are ok to leave on for daily use I'm hoping too. Not sure how much lower they hang
'22 2SS 1LE manual in Red Hot with Red seat belts, rotofab intake, catch can and everything amsoil.
ColeD is offline   Reply With Quote
Old 05-04-2023, 01:40 PM   #7
FollowMyLine
Driver for Hire
These are the mini rotor dust shields that are stock on the ZL1 and ZL1 1LE. The SS has larger brake rotor shields. These are in addition to the ducts. They are absolutely ok to run on a daily basis and do not hang as low as the SS track brake ducts did.
Attached is a photo of the Blackwing duct on the left and SS track kit on the right, for reference.
Luan Zeqollari
YouTube Channel
Old 05-07-2023, 05:17 AM   #8
ColeD
ColeD's Avatar
Thanks! So if I have a 1le already I don't need the dust shields? Seems like a pretty cheap and effective upgrade im definitely going to try to pick a pair up
Old 05-07-2023, 08:37 AM   #9
FollowMyLine
Driver for Hire
Only the ZL1 and ZL1 1LE come with the mini dust shields. The SS and SS 1LE have the full rotor shields and need the mini dust shields.
Luan Zeqollari
YouTube Channel
Old 05-07-2023, 12:45 PM   #10
No, there are 3 types of brake dust shields. The full one is what the SS comes with, the SS 1LE and the ZL1 come with "half size" ones installed.
I think the small (or track) shields are installed by default on ZL1 1LEs, although this last bit I am not 100% sure about as I haven't seen it on a ZL1 1LE and online sources are contradictory.
Part numbers are as follows:
"Full": 22802367 (left), 22802366 (right)
"Half": 23336595 (left), 23336594 (right)
"Small": 23385146 (left), 23385147 (right)
Old 05-09-2023, 01:00 PM   #11
FollowMyLine
Driver for Hire
Hey, I learned something new! Awesome info.
Luan Zeqollari
YouTube Channel
Old 05-10-2023, 05:22 AM   #12
ColeD
ColeD's Avatar
Will the blackwing ducts fit with the half shields or does it have to be mini still?
Old 05-10-2023, 08:40 AM   #13
Honestly, I don't know. However, everyone should already have the small shields (they come in the trunk even with the standard SS), so it's easy to have a working setup while figuring out whether the bigger SS 1LE shield fits or not.
Old 05-11-2023, 10:18 AM   #14
FollowMyLine
Driver for Hire
The Blackwing duct will fit regardless of what shield is at the back of the rotor. To get the full functionality, you would want the mini shields installed.
The SS hasn't come with the track brake kit in a very long time. I believe that was a 16-17 only, and my 2018 did not include them, and my 2022 didn't either.
Luan Zeqollari
YouTube Channel
