Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 04-28-2023, 11:42 AM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
Morimoto Xb Led Taillights Smoked MOR-CAM-LF401 For 2016-2018 Camaro
Housing Finish: Black
Lens Finish: Smoked
Bulb Type: LED
Bright Red LED Turn Signal and Brake Light
Bright White LED Reverse Light
Optional Sequential Function
Direct Factory Replacements
ABS Plastic Housing
DOT Approved
Plug and Play Installation
No Modification Required
Easy Installation
Sold as a Pair
These lights provide another alternative to the factory taillights by giving you a completely different look to you Camaro. These lights have a unique sequential light function or a standard light function giving you a option to customize your look. Built with full LED circuit boards allowing for a bright Red stop and turn signal function, also integrated in the circuit board is a bright White LED reverse light. With the bright LED circuit boards these lights offer a much better illumination over the factory halogen bulbs. These lights feature Smoked lenses. The Clear lenses for the reverse and brake light functions for a clear view of their operation.
One of the standout features of the Morimoto XB LED Taillights is their unique "sequential" turn signal function, which uses a series of LEDs that light up in a sequence to indicate the direction you're turning. This function is not only a cool visual upgrade, but it also provides better visibility to other drivers on the road.
APPLICATION: 2016, 2017, 2018 CHEVROLET CAMARO
southerncarparts is offline   Reply With Quote
Old 05-01-2023, 03:04 PM   #2
southerncarparts
Please shop here : https://www.southerncarparts.com/201...ts-smoked.html
Copyright ©2000 - 2025, vBulletin Solutions, Inc.
