04-27-2023, 01:05 PM | #1 |
Drives: 2019 2SS 1LE Join Date: Mar 2020
Tremec TUET11012 Swap?
So I was watching Doug Demuro's video on the IS300 wagon and he mentioned how those cars are swapped, decided to do a curiosity Google search and found out the T6060 (T56) is a popular swap for these, but I also noticed something curious, there's a T56 with lower gear ratios for 1st, 2nd and 3rd, decided to input the numbers in a calc and this are the speeds I got at 6500 rpm.
1st: 2.97 @ 48 mph (vs 2.66 @ 54 mph) 2nd: 2.10 @ 68 mph (vs 1.78 @ 80 mph) 3rd: 1.46 @ 98 mph (vs 1.3 @ 110 mph) 4th: 1.00 @ 143 for both One of my pet peeves with the Camaro is that the gears are too loooooong and it would this swap would make it more fun for spirited/track driving seeing you're changing gears more often at the cost of cruising comfort and city MPG (but who cares?). So I'm just posting this to get opinions/thoughts, wondering if all the features like no lift shift and rev-matching would still work.
Current: 2019 2SS 1LE aka "Blanc"
Previous: 2017 2LT aka "Noire" Mods: Chevrolet Performance Suspension || K&N Cold Air Intake || Borla ATAK Mufflers + Catback system || MRR 650 ZL1 replicas with squared 285/30 Michelin Pilot Sport 4S || ZZP 4 piston brake kit + braided brake lines || BMR everything (Solid/Lockout cradle bushing are a MUST in Camaros) |
04-27-2023, 01:28 PM | #2 |
Who Needs to KNOW?
As someone who owned a stupid geared IS300 that would buz 4K rpms at 80mph.. no thanks!
Change the rear end... easier path. Even easier... shorter tire.
ing for grip.
04-27-2023, 01:46 PM | #3 |
Don't think there's any any options for the e-diff, plus 4th, 5th and 6th and the same ratios so it would have the same issue.
04-27-2023, 02:03 PM | #4 |
Who Needs to KNOW?
Magnum version of tremec is essentially beefier version of TR6060 and that can be ordered w custom gear ratios (or at least some of them).
https://www.txdrivetrain.com/product.../tr6060-gears/ Sounds like easy way to spend $10-15K
ing for grip.
04-27-2023, 02:13 PM | #5 | |
04-27-2023, 02:24 PM | #6 |
Who Needs to KNOW?
well.. by the time you drop the trans, crack open the gear case, swap in however stock parts they are.. you're few $K in labor and parts. And if you have to ship it in either directions.
https://americanpowertrain.com/shop/...magnum-for-gm/ I guess cheaper than I expected but its for T56.. not the TR6060 family. AFAIK it's not the same-same.
ing for grip.
04-27-2023, 06:08 PM | #7 |
Drives: like an old lady Join Date: Jun 2012
t56 magnum is mostly the same as 6060 internally. same power ratings.
