Old 04-26-2023, 02:06 AM   #1
CYN_CRVR
CYN_CRVR's Avatar
Drives: 2023 RS
Show me your 19x10 ET20 SQUARE setup
I'll be considering this setup for my 1LT with street alignment (figure about -1.5 camber). I see Apex calls this a "direct fit" with 275/35 or 285/35 tires on non-ZL1 cars, so I assume there's no need for spacers.
So, I'm really just interested in how the tires align visually with the front and rear fenders. Some photos would be worth a thousand words in this regard.
Thanks,
CYN_CRVR is offline   Reply With Quote
Old 04-26-2023, 01:49 PM   #2
Boostamoose
Drives: 19' 2SS
This is not exactly what you're looking for, but I have a very similar setup.
SM10 ET20 wheels 19x10 wrapped with 275/40 19R square setup.
https://imgur.com/a/wCy7j8s
Boostamoose is offline   Reply With Quote
Old 04-26-2023, 08:37 PM   #3
CYN_CRVR
CYN_CRVR's Avatar
Drives: 2023 RS
Very helpful, thanks! They seem to stick out a little bit more than I'd prefer, but still within reasonable bounds, IMO.
Old 04-29-2023, 01:46 PM   #4
pierrotss
Drives: Chevy Camaro SS 2019 convertible
https://www.camaro6.com/forums/album.php?albumid=22593
Here. Apex with square 285/30R19
pierrotss is offline   Reply With Quote
Old 04-29-2023, 11:22 PM   #5
CYN_CRVR
CYN_CRVR's Avatar
Drives: 2023 RS
Originally Posted by pierrotss View Post
Wow, you must have gained a nice gearing advantage by sizing down to the 30 aspect ratio.
Old 04-30-2023, 04:03 PM   #6
pierrotss
I probably should have listed the wheels specs:
19X10" ET20 APEX ARC-8 CAMARO WHEEL
Old 05-04-2023, 08:44 PM   #7
wilbur_xmas
wilbur_xmas's Avatar
Drives: 2020 2SS 1LE
275/35 R19 mounted on APEX ARC-8 19x10" ET20 wheels front and rear on my old (grey) V6 1LE and new (red) 2SS 1LE. V6 1LE was running -2.4 camber front and -1.5 rear. 2SS 1LE camber is at -2.8 front and -2.3 rear. Tried to pick a mix of static/dynamic down-the-side shots to give you a better idea of... , ah who am I kidding I just wanted an excuse to post some cool pics.
For what it's worth the tops of the tires were basically dead-nuts flush with the rear fender when statically loaded on the grey car with the fronts slightly tucked due to camber. The tops are tucked on the red car front and rear, but I have some 295/35 R19 tires waiting in the wings that should bring the tire back out nicely...
wilbur_xmas is offline   Reply With Quote
Old 05-05-2023, 03:48 PM   #8
Silent_H_
Silent_H_'s Avatar
Drives: '21 V6 1LE
This is super helpful man! No spacers on the old setup?
Silent_H_ is offline   Reply With Quote
Old 05-08-2023, 03:10 PM   #9
wilbur_xmas
Correct, no spacers. Basically perfect fitment with no compromises out of the box!
Old 05-11-2023, 01:27 PM   #10
Camaro Fanatic
Drives: '23 1SS 1LE
I've been looking at APEX 19x10" ET20 as well to avoid spacers for my SS 1LE.
Plan to swap between stock wheels and these often once I start to track it.
Notice you mentioned you have 295's ready. Are they the RT660's by chance in the background? I've been wanting to run something square and close to 305 without having to run 11" rims and play with spacers.
Have you put 295's on a 10" rim before and if so have you seen any drop in performance/feel?
Thanks!
Camaro Fanatic is offline   Reply With Quote
Old 05-13-2023, 02:23 AM   #11
wilbur_xmas
Thanks!
Yes 295/35R19 RT660s. A 10" rim is the minimum recommended by Falken for the 295 width, and they are slightly pinched. I don't have a great basis of comparison since the only other tires I have tried are the vastly inferior Federals, or factory runflats that come on the I4/V6 1LEs or base SS, but I just tried out the RT660s today at Thunderhill East and they forced me to recalibrate my brain for what speeds I could maintain through the corners. I couldn't ask for more from an easy rotatable setup that doesn't require lugs/spacers. Every aspect of the Falkens was an improvement: stiffness, feel, turn in, grip levels, temperature tolerance, wear, etc... with the sole exception being that the Falkens are heavier. The only slight issue I had was a minor rub on top tip of my rear splashguards but that self-clearanced quite nicely. That said, if I didn't already have the 19x10 wheels and get a stupid deal on the RT660s, I probably would have just thrown factory sized SC3s on the factory 1LE wheels and called it a day.
Old 05-17-2023, 08:01 PM   #12
enzia35
Drives: '16 Garnet Red 1SS
I miss my Camaro with the Apex wheels. Loved the poke of the 19x10 et20 setup.
'16 Camaro 1SS
'18 Miata GT
Old 04-24-2026, 11:58 AM   #13
1leAL73
1leAL73's Avatar
Drives: 2022 Chevrolet Camaro SS 1LE
This was a huge help for me in 2026! I've had my 1LE for 1 year now and have been looking to go with a square setup without having to use spacers or grind the mrc shock tower. My current setup is staggered 19x10 ET20 with 295 30s up front and 19x11 305 30 in the rear. I think I will be going with your setup.
1leAL73 is offline   Reply With Quote
