Old 04-24-2023, 08:04 AM   #1
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
bouncing feeling when tires are cold?
So, I went to my first Cars and Coffee Saturday morning here in Columbus! It was pretty cool! I had a lot of compliments on my car and my mods! I left the my house around 8:30am when the temp was around 45°. When I got to speed on the freeway, my car literally feel like it was "bouncing". When I slowed down to exit the freeway and drove on a 35mph street, the bouncing feeling went away. But, when I left Cars and Coffee to head home. The temp was almost 60° and on the freeway, the ride seemed smooth and no bouncy feeling. Could that bouncy feeling been an issue of the cold temp and the Goodyear F1's being cold? Thanks !
2023_ZL1-AUTO is online now   Reply With Quote
Old 04-24-2023, 08:04 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Out of balance?
'20 ZL1 Black "Fury"
Old 04-24-2023, 08:13 AM   #3
2023_ZL1-AUTO
Drives: 2023 ZL1
Out of balance?
I guess possibly... It just only happened the one time when it was really cold and tires were cold. That's what made me wonder if temps can cause it. I'm going to hit that same part of the freeway when it's warm and see if I feel the bouncing again. I guess it could be that section of road, our roads in Columbus SUCK! I was in track mode too, so that could have been part of the "extra" noticeable bad road conditions.
Old 04-24-2023, 08:19 AM   #4
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
I guess possibly... It just only happened the one time when it was really cold and tires were cold. That's what made me wonder if temps can cause it. I'm going to hit that same part of the freeway when it's warm and see if I feel the bouncing again. I guess it could be that section of road, our roads in Columbus SUCK! I was in track mood too, so that could have been part of the "extra" noticeable bad road conditions.
If it’s only when cold, your theory is correct. The super car 3 tires are hard as rocks when driven in the cold.
m6-lt1 is offline   Reply With Quote
Old 04-24-2023, 08:36 AM   #5
SmittyZ
SmittyZ's Avatar
Drives: 23 ZL1 VERT
I don’t know if I’ve ever noticed the car being bouncier when it’s colder out. Traction is definitely an issue. I daily mine, and the past few months its been in the 40s and 50s here in the AM. I will say that several times I’ve hit a stretch of highway out here that looks smooth but it is actually not, and the ride is actually bouncy though those stretches. Could it have possibly just been the road? These things are pretty sensitive to any and all road imperfections.
SmittyZ is offline   Reply With Quote
Old 04-24-2023, 08:50 AM   #6
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I find that with a lot of low profile, high performance tires, you get some flat spotting on the tires when sitting for a few days, particularly in cold temps. Then it goes away as you drive and the tires warm up. I'll get that on my cars in cold temps, or even if they sit for a week while I am away in warm temps.
Mods being installed-
Old 04-24-2023, 08:55 AM   #7
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Flat spots feel like it's not bouncy is just a really rough ride. I've not seen it with SC3's. Roadway, cold tires as said these things are hard as a rock when their cold, track setting could have been it but I think you got your answer when you drove out and it was 60 and it rode fine.
Old 04-24-2023, 10:07 AM   #8
Greg83
Drives: 2023 ZL1 M6 Sharkskin
My SS-1LE with the same tires did that early this spring. Cold flat spots. I think it’s normal for these extreme summer tires. We are not supposed to be driving on them below something like 32 degrees. I don’t drive on mine below 40 degrees. It should go away after the tires and weather warm up.
2019 Porsche 911-T M6-SOLD
2020 Crush ZLE A10-SOLD
2023 Red Hot ZLE M6 ordered 5/9/23, never built
2022 Shadow Grey 1SS-1LE M6-SOLD
2023 Sharkskin regular ZL1 M6-SOLD
Greg83 is offline   Reply With Quote
Old 04-24-2023, 10:36 AM   #9
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
OEM tire grip drops off quick below 60F and they are as hard as hockey pucks below 40F. So yeah OP was probably skip-sliding down the road like metal strap on roller skates on 20 year old asphalt.
Old 04-24-2023, 10:48 AM   #10
FarmerFran
FarmerFran's Avatar
The tire compound gets harder in that temp range. So less compliant. Could be what you are feeling.
<Insert Cars You Own Here>
Old 04-24-2023, 02:56 PM   #11
laynlo15
Drives: 2022 Lt1 A10
Check pressures and you probably have flat spots in them and only shows up whent the tires are cold and go away when warmed up.
Old 04-24-2023, 03:46 PM   #12
Z OH 6
Drives: 2024 CT5-V Blackwing
I've never felt any bounce in mine no matter the temps outside. I have felt flat spots from letting my car sit too long without driving it, but it feels more like a very minor out of balance and goes away after driving it for 5-10 miles.
Old 04-25-2023, 07:20 AM   #13
2023_ZL1-AUTO
Drives: 2023 ZL1
Check pressures and you probably have flat spots in them and only shows up when the tires are cold and go away when warmed up.
Pressure is 35lbs in all four tires. Car is in garage, I will put my QuickJacks under it this evening and see if I have any flat spots. I'll make a curved template and check them 360° The car did sit mostly for a few tires with only one quick drive to make sure my new Carbo Wheel was installed at 0°. But have not driven it much at all. The garage does get cold unless I keep the split unit on. But I only do that when I know I'm going to be out there working etc.
Old 04-25-2023, 07:50 AM   #14
Z OH 6
Higher tire pressure helps but if you let the car sit for two weeks or more without driving it, you can get some mild flat spots that should go away after driving for a few miles and getting the tires up to normal operating temp.
