Snow Tire Recommendations
Hello all,
I have a 2023 ZL1. I currently live in Wyoming and will be here for the remainder of the year. I know that the factory tires crack when under a certain temperature. What in your opinion is the best all around tire or snow tire? I plan to drive the car mostly on weekends. For reference the temps here are still in the 30s with them being in the high 20s in the morning |
#2 | |
![]() Drives: Chevrolet Camaro LT1 Join Date: Sep 2022
Currently, I live in The Province of Alberta in Canada, where studded tires are legal for winter use. IF you live or are staying in, a jurisdiction that allows studded tires, they can be bought on a number of the Nokian tire models. I have the studs on my Hakkapoleda tires on my Ford Maverick pickup truck, and I have NEVER lost traction, no matter the road conditions. However, all that being said, you might have trouble getting any Nokian tire right now, particularly so in Camaro ZL1-appropriate sizes, as Nokian used warehouses in Russia until Russia invaded Ukraine, and Russia has prevented Nokian from pulling their tires out of Russia. So, there is currently an acute shortage. I have had good results though also with Michelin X-Ice tires, and with Brdigestone Blizzak tires. Those tires are of course more generally available, and are as good as you can get other than Nokian. One thing to remember when buying winter tires: Narrow is apparently better than wide. The narrow tires penetrate snow to reach a tractive surface, while wider tires tend to "hydroplane" on snow. Cold, snowy, and icy road surfaces require a good combination of cold weather rubber that resists hardening and even cracking in the cold, and a tread pattern that will work on BOTH deep snow AND glare ice. That is a tough combination to optimize when the temperatures, snow, and ice conditions vary from day to day, particularly in a high elevation, northern location like Wyoming. Try to find a true tire PRO familiar with tire theory AND local conditions versus just a salesman when searching for the best tires for your specific location. Note that some non-winter tires MUST not be used in cold weather. My Nitto NT555R2 tires are one example. Nitto warns buyers that operating them, or even just moving the car a short distance, in temperatures of minus 9 C = 16F or lower, can cause them to crack and thus become unsafe and unusuable. But, with my Magnuson suprcharger, and the narrower wheels on my 2022 LT1, the 555R2 tires are a necessity. Without them, the car breaks traction all the way from 0 to at least 85 mph (that's the fastest a wise driver dares to go on our policed roads to avoid draconian results). So, I don't drive the Camaro in really cold weather nor in rain, snow, or ice at all. But if I needed to drive it "daily", I would buy the best winter tires I could for it, just as i HAVE done for my Ford Maverick pickup truck. Jim G |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
Stock ZL1 should not be driven in under 40°F. At 20°F if the tries flex they can crack.
How much snow we talking? If it is just general snowy conditions I would say something like this https://www.tirerack.com/tires/tires...1&autoModClar=
<Insert Cars You Own Here>
#4 | |
Jim G |
#5 | |
Shadow Gray '19 ZLE M6
I suspect you may be looking for an all season tire recommendation, but can you clarify?
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
#6 | |
I would not run these tires year around but rather only in the winter time and switch to the factory tires during summer |
#7 | |
Jim G |
#8 | |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
I don't use an A/S, it's not good enough and a snow/ice tire is more than I need in my area.
In the middle and what I do use is a Winter Performance Tire, and I HIGHLY recommend the Michelin ALPIN PA4. I used that tire 3 or 4 seasons now on stock 1LE and ZL1 wheels; 275/35/20 and 285/35/20. |
#10 |
Who Needs to KNOW?
Blizzaks LM-32 are decent choice. Not as good a Michelin X-Ice I had on previous car ( better ride quality).
#11 |
#12 |
Ive run the XI2 and XI3 studless snow and ice and I just don't have enough snow days to need that much tire. I have 5-7 days in winter with snow on the streets. All the other days in the winter season, IMVHO, those tires suck ass to drive on. Theyre terrible outside of snow on the ground, I hated them.
#13 |
Who Needs to KNOW?
I have 2 sizes on there right now, both 275 wide. I wore through a set of rears already, which were same size as front.
Currently: Front: 275/35R-19 Bridgestone Blizzak LM-32 Rear: 275/40R-19 Bridgestone Blizzak LM-32
#14 |
This thread makes my head hurt, very bad or badly or baderester.
