![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
COOKING starters at the racetrack
Well to those that know me, I pretty much tax the limits of most things car related and apparently I am COOKING the starter on my Car at the track .
I was ECR this SATURDAY and after the FIRST SCCA TT track session at a pretty fast pace (2.02 see YOUTUBE link in my signature below), I pulled into my pit spot and after parking the car, I was never able to restart the car again from that time forward. Whenever you pressed the starter button the car would not even ATTEMPT to start. NADA. Now this car has 2 inch KOOKS headers, runs Zl1 upgraded brake package with DTC70 pads and MICHELIN Slicks on all four corners 30 65 18. I NO DOUBT get hotter than 95% of the people that are tracking their cars so hopefully YOU wont have this issue. This is the SECOND starter I have cooked so THIS time we are putting some additional heat shielding around it or rather AMP is. This should solve the issue.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
Just a thought - add an engine to body ground cable. I too have dealt with a heat-soaked starter. Adding the ground cable has significantly helped my slow cranks (and one no crank). IMO - worth a shot for $20.00 bucks and ten minutes of time. Here are the details if interested: https://www.camaro6.com/forums/showthread.php?t=586153
#3 | |
![]() ![]() Drives: 17 hyper blue 2SS M6 Join Date: Mar 2018
My car always cranks slow when I just get off track. I replaced the starter before it failed the last time since I already was doing something that required the header to be off.
I tried adding the ground cable and it did not help my situation at all. There are plenty of positive reviews on adding the ground but it just didn't help me. I plan on changing the starter anytime I need to take the header off, there's just too much heat in there for it to have any longevity, in my opinion of course ... |
My take is that aftermarket headers make the heat soaked starter issues even worse. With stock exhaust manifolds and the meager factory heat shielding- it takes a strong battery and the lowest circuit resistance possible (the extra ground cable gives that) to overcome the starter heat soak. The added heat that the header tubes throw into the starter is just too much to overcome especially once the starter windings start to deteriorate from repeated heat soaked start cycles over time.
My suggestions would be a to take multiple steps. Start with a fresh starter and good battery. Keep the battery fully charged at all time (keep it on a charger whenever possible). Add the ground cable. And get as much heat shielding as possible between the headers and the starter. Good luck guys. This is a frustrating problem.
#6 | |
#7 |
Moderator
I didn’t see it mentioned…are the headers coated? I suspect that would help a good amount.
#8 |
![]() Drives: Camaro zl11le Join Date: Oct 2021
Cermaic coat headers or heat wrap? Add louvers to the hood to help heat extraction as well as downforce.
#9 |
While ceramic coating on the OUTSIDE of the header WOULD result in lower surface temperature, there is the theory that the coating also would keep some of that heat inside the header tubes as well which WOULD NOT be desirable as you would want to extract that heat as quickly as possible AWAY from the engine..
#10 |
I've never had an issue in 5 years of tracking mine, but I don't have headers or 600+hp. Besides the other ideas, maybe install Race Louvers to get the heat out and also open the hood after coming off track.
https://racelouvers.com/chevy/chevy-...-gen-6/?page=2
Mods: MSD, Headers, 95mm TB, high flow cats, full 3" exhaust, SPL, MCS 2-way remotes, sway bars, rear diff lock outs, Sparco racing seats, 6 point harness, CMS roll bar, Nine lives wing, 6" splitter, ACS canards.
www.youtube.com/@Racer_Mike87 |
#11 | |
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
#13 | |
#14 |
![]() ![]() ![]() Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
If it is a manual you could try getting a person or two to push the car with the clutch pedal pressed down in 1st gear and pop the clutch at around 10mph. It was able to bump start a lighter manual transmission car after the started failed by pushing it myself with the drivers door open and hopping in but that wasn't the safest thing to do and idk if it would work in the Camaro.
