![]() Drives: 2019 Chevrolet Camaro SS Join Date: Apr 2021
Rear Suspension Set up
What are you folks running for you drag racing set ups? As far as front suspension, and rear suspension.
Was also lookin at the QA1 weld in kit, has anyone done this? I couldn’t find very clear instructions on this setup, as far as where the bar that runs across the width of the car gets placed. And talk to me a little bit about spring rate as well, not sure what the best option would be. The power level i'm going to be dealing with will probably be around 1000 horsepower. I’m not very certain on weight at this moment, because i will be getting a cage, but will also be replacing the seats with kirkeys, and removing the rear seat. |
| Tags |
| advice, drag car, drag coilover, suspension |
