![]() Drives: Chevrolet Camaro Join Date: Mar 2021
Retune required?
Ive absolutely burned the search function up both on the site and through google but sometimes its just worth asking yourself haha. I have a 19 SS with longtubes, xpipe, axle back and e85 tuned. The tune was performed directly after all the mentioned mods were done. Im now thinking about buying a rotofab as well as an lt2 intake. The question is pretty simple, after i install will the car REQUIRE a retune? I understand the ideal situation would be yes, but is it an absolute dire must? I ask mainly because it could take me a while to get back into my tuner.
Thanks!
2019 Shock 2SS
BTR220 Cam, LT’s, Borla Atak, LT2 Intake, E85 Tune by RPP |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
LT2 intake yes, you will need a tune, and the tune will optimize the rotofab as well.
LT2 with no tune will lean out your current tune, and retune will be needed to make sure not running to lean. Depends on your current tune settings of course, often there is room to play with the intake, I think it only changes the lean tables by a few points, and if you have enough margin below running to lean, than you might be ok, but its a risk you take if your current tune is maxed out on running lean already. If it was just the rotofab I would have said no.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
My advice from way back has always been the same. You spent that much $ on a vehicle to modify, every change at least check the tune.
<Insert Cars You Own Here>
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
I ran my unported LT2 intake, with a solar 91 mm TB and I modded my own factory air box for more flow and removed the snow block in behind the grille that obstructs the air intake area for two months with absolutely no issues before I had the car tuned. The ECU does adjust somewhat to the extra air flow over time and as long as you do not do to many WOT pulls, you should be fine till you get to the tuner.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
i did almost exactly what you are doing.
ported LT1 manifold long tubes ethanol tune cut stock airbox went to a rotofab and LT2 manifold. with no tune changes the car barely leaned out, .01-.015 lambda. but the car picked up 1-1.5 mph via dragy. i had that setup on the car for a few weeks with several 60-130 pulls and lots of street miles. it is best to monitor these things yourself as every car, tune and tuner are different. i don't think the rotofab contributed much, if any, to the gain. the stock cut airbox and rotofab testing i previously did showed no gain. i'm a big fan of the LT2 manifold for basic bolt on cars. edit: retune required? most likely not. but to get the most youll want it touched up and the rev limiter raised at minimum.
#6 | |
![]() Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
#7 | |
![]() Drives: 2020 Camaro SS 1LE Join Date: Apr 2022
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS 1LE Join Date: Aug 2013
I believe this is the case due to movement of the throttle body as it is higher. This clocks the tube and throws off the reading. I would tune for optimal fueling.
#9 |
Not saying you're wrong but I don't understand what you mean when you say moving the throttle body up higher clocks the tube and throws the reading off?
#10 |
![]() Drives: 2017 2SS F1FTY Join Date: Feb 2020
Hoping to piggyback a little off this: I already have the LT2 IM and 95mm TB both GPI ported. I just don't like the look of it. I will either be getting the C8 engine cover or going with the MSD. If I go MSD, what's the consensus on needing a retune?
2017 2SS F1FTY/HUD/Mag Ride/NPP/Nav/M6/Mishimoto catch can/BTR stage 2 Cam kit/GPI ported LT2 IM and 95mm TB/Roto Fab CAI/Kooks Long Tubes ceramic coated/Borla S Type NPP catback/AFE lowering springs/1LE wheels/OEM smoked tail lights/Diode Dynamics side markers/Uniden R7/3D Maxpider floor mats/Adams graphene ceramic coat
#11 |
Anytime you change mods the tune should be checked.
#12 |
usually retune is cheaper with the same tuner
#13 |
![]() Drives: CAMARO 2SS Join Date: Jun 2025
WHAT IF MY CAR IS COMPLETELY STOCK
#14 |
![]() ![]() Drives: 2017 2ss 6mt Join Date: Mar 2024
