Old 04-12-2023, 12:18 PM   #1
JTS
JTS's Avatar
Drives: 2023 ZL1 A10
Plug or Patch Tire
Hi All , picked up a screw in Right Front Tire , I had plans to take the T an W to Discount tire for a patch , and most likely will . I decided to plug ,
I didn't want the T an W separated . The plugs were rust colored and kinda gooey feeling . Last time I plugged a tire was 33 years ago my ATV .
So what's the consensus Plug or Patch .
2023 ZL1 A10 Shadow Gray Metallic
JTS is offline   Reply With Quote
Old 04-12-2023, 12:35 PM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
Would rather have a patch but the last time I had one done at Discount Tire they called it a plug/patch combo saying that its patched on the inside with a plug that sticks out. I hate the way a plug looks sticking out of a tire.
Old 04-12-2023, 01:58 PM   #3
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
I agree, patch 100% of the time when you can! Only if the patch can full stay flat on the inner tire and not wrapped around the corner/sidewall (on the inside). Plugs, are not so good.
Old 04-12-2023, 03:04 PM   #4
Mark R
Drives: 2018 ZL-1
I plugged a nail hole on my wife's car so I could limp it to Discount Tire. Big mistake. They would not patch it from the back since I had plugged it on my own. As a result, with her AWD Nissan Rogue, I had to buy 4 new tires, because the AWD system needs tires of the same diameter, otherwise the AWD system freaks out.
Next time, I'll take that sort of thing to a local shop for a patch.
Old 04-12-2023, 07:42 PM   #5
Jus Cruisin
Old Gearhead
Jus Cruisin's Avatar
Drives: 2023 GMC Sierra Denali Ultimate
I've plugged many tires over the years. Zero failures. I carry a plug kit and a Viair inflator in my truck. Bias, radial, run flat, done them all
2023 Camaro ZL1 convertible - black - SOLD
2025 GMC Sierra Denali Ultimate - black - 3.0l diesel
1937 Ford Slantback
Jus Cruisin is offline   Reply With Quote
Old 04-12-2023, 08:06 PM   #6
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Definitely patch the tire. Goodyear won’t warranty the tire if you plug it.
Old 04-12-2023, 08:09 PM   #7
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
long term plugs can allow moisture to creep in.
Old 04-13-2023, 06:13 AM   #8
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
I had a screw in one my GYs and had it plugged and patched. Held up fine for 3 years until I replaced them with PS4S. Don't think I would trust just a plug for the way these cars are meant to be driven.
Old 04-13-2023, 06:48 AM   #9
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Most tires you can plug and be fine but not ultra summer Z rated tires, if you care to maintain the integrity of the tire and its capabilities. Always patch it. You're not being rational about the patch and dismounting the tire, and last time I had one done it was $16. The plug ain't gaining you anything at all here.
But I wholeheartedly agree that tires have been plugged since the tire was invented but there's a much better method especially for this type of tire.
Old 04-13-2023, 06:50 AM   #10
WhiteMale
They're supposed to trim off that little tail flush to the tread and it otherwise should wear itself off.
Old 04-13-2023, 07:02 AM   #11
ctrlz
Yes, that's a bit sloppy. I would hit it with soapy water too, to check their work.
Like others above, I have plugged tires for years and the only time I had one leak was when I double-plugged a tire while I waited to replace it. Turned a big hole into a tiny leak and got me through.
If I was tracking the car and the plug was near the edge I might be concerned. That hole being in the center, I bet it never comes loose if plugged properly.
Old 04-13-2023, 07:31 AM   #12
LeonardS
A plug patch is the way to go. It’s a rubber patch and rubber plug combined together. They use a special glue that seals the area where the plug goes through the tread and the patch is a normal looking piece. This offers the best protection from water intrusion into the core of the tread.
94 Z28, Black, M6, 595 miles
69 Z28, Dusk Blue, M4
29 Ford Business Coupe
28 Ford Pickup
24 GMC Denali 2500HD CCSB 4x4
22 Jeep Grand Cherokee
13 Ford F150 Crew Cab 4x4
Old 04-13-2023, 08:48 AM   #13
Drnick
Drives: 22’ ZL1
I had a similar experience,simple fix, which lasted till tire
Wore out…. If it’s on front tire and screw is located where
U pictured, don’t even have to remove wheel….just buy
A tire repair kit (less the $10) follow simple instructions
I put over 5000 miles never had a problem.
Drnick is offline   Reply With Quote
Old 04-13-2023, 09:38 AM   #14
ctrlz
Unless I'm reading the wear indicators wrong, that tire looks like it's close to replacement anyway.
