![]() Drives: 80 Z28 - 93 Z28 - 14 Camaro SS-RS Join Date: Sep 2016
ZL1 Oil Pump How to Replace
I have a 2018 ZL1 and I am not sure of the build date. I am looking to replace the oil pump just in case. I have a garage with a lift. I just wanted to pick someones brain on how to replace the oil pump. Do you have to pull the motor? Is it easier through the bottom? Any info would be great.
1980 Z28 AWSM-Z
1993 Z28 AWSM-Z 2014 2SS AWSM-SS 2018 ZL1 AWSM-Z |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
You'll need to pull the entire front end off since it's located on the front of the engine. That's why a vast majority of people who replace it only do so if they are doing a cam drive it's labor intensive or if it actually fails.
You don't have to do the engine but you can if you want and have the ability to do so. You might be able to get to it from the underside but I don't know if that really is an option. The build date can be found on the sticker in the driver's door. It'll be close to the top left corner of the sticker. |
Does anyone know the part number of a bolt that is supposedly one time use when changing the oil pump? Thanks.
Sarcasm loading --------
the crank pulley bolt is one time use.
551218 They are really cheap for how big the bolt is. you will want to get a flywheel locking tool.
2018 MBM ZL1 1LE - 652 rwhp, 588 rwtq SAE 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I'm pretty sure that the balancer bolt can be reused, however, the installation procedure is different for new vs used bolts. Personally, I would go with an ARP bolt. The high torque requirement and shallow head on the OEM bolt makes me nervous. It would be a read PITA if the head rounded off when attempting to remove the bolt. The ARP has a really deep (~1"), 12 pt head. No way you're rounding that sucker off.
Baby Blue
![]() ![]() ![]() ![]() Drives: 2018 ZLE Join Date: Feb 2018
Sounds like you should drop it off at a shop.
#7 |
I hope this wasnt for me since I was a GM tech for 10 years back in the late 80s early 90s. Everyone has to do a job for the first time. Working in a dealership you get a lot of tips and tricks to do it quickly as they pay flat rate. I just wanted to see if someone had seen a video or had some insight. The last time I changed an oil pump it was in the bottom of the engine inside the oil pan...
1980 Z28 AWSM-Z
#8 |
So has anyone replaced their own? A good shop in Maine is hard to find.
1980 Z28 AWSM-Z
#9 |
Lamude Racing Engines
Drives: 2018 ZL1 Hyper Blue Jennetty tuned Join Date: Feb 2022
I will be doing mine soon,going the Katech route,was thinking of doing a step by step thread,for those wanting to do it themselves !
#10 |
![]() Drives: Buick Grand National, BMW M5 Join Date: Nov 2019
#11 |
Yes please that would be great. Mine has a build date of 1/2018 and it seems to hold decent oil pressure at 31 PSI at idle/ I am looking for the actual specs right now. I thought it was under 20 at idle or something at 1000 rpms?
1980 Z28 AWSM-Z
#12 |
2018 ZL1
Build date june 2017. My oil pressure is perfect 30psi hot at idle,with 13,000 miles,so its a pre-emtive change rather than a failed part.might start next week,as already have the new pump. |
#13 |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
I replaced mine during my phase.2 upgrade of cam, heads, ported blower, etc...
https://www.camaro6.com/forums/showt...hlight=PHASE.2 There are a lot of great you-tube videos that will help. I'd search for cam swap videos first and that will get you close. Do you have any other plans to upgrade the car? At the level you are at to upgrade the oil pump, the following upgrades seem like a no brainer to me... Assuming you had plans to modify. I listed them from the cheapest / easiest - to the least necessary, but easy while everything is apart. 1. Upgrade to the Katech oil pump 2. Upgrade to the Katech C5R Chain 3. Upgrade to a LME chain guide 4. Upgrade to an ATI Damper + OD Pulley 5. Change front main seal 6. Replace all belts 7. Install lower t-stat 8. Upgrade front HX 9. Cam Swap 10. Port and clean up your heads / vale train 11. Ported blower 12. VVT Delete front cover 13. DoD Delete valley cover 14. Sorry for the long list, i think you get the idea
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#14 |
Thanks SoCal I will have to look up some of these updates. The Cam seems like a no brainer and I intended on doing the Kong Stage X 103 MM TB and a 2.3 upper pulley on mine. I am scared of the oil pump and I bought the car used so I have no idea if its been done. Mine is a M6 so I dont know if I have the same challenge with the DOD Valley cover. Is that for the Auto only like on the SS where it drops cylinders? Why wouldnt you want the VVT? I thought that was good for power?
1. Upgrade to the Katech oil pump 2. Upgrade to the Katech C5R Chain 3. Upgrade to a LME chain guide 4. Upgrade to an ATI Damper + OD Pulley 5. Change front main seal 6. Replace all belts 7. Install lower t-stat 8. Upgrade front HX 9. Cam Swap 10. Port and clean up your heads / vale train 11. Ported blower 12. VVT Delete front cover 13. DoD Delete valley cover 14. Sorry for the long list, i think you get the idea [/QUOTE]
1980 Z28 AWSM-Z
