Old 04-10-2023, 09:36 AM   #1
BeauRichardson
Drives: 2019 Chevrolet Camaro SS
Procharger and 2-Step
Anyone have any experience using a 2-step on a procharged car? Was testing and couldn’t rev past 2700, it was pushing through the brakes. But because of only being able to go about 1/2 throttle, i wasn’t able to close my BOV so it left the line really slow. How much boost have you seen on a similar set up?
Currently waiting on the 10 Speed Launchbox to be released so i can use that as a trans brake
BeauRichardson is offline   Reply With Quote
Old 04-10-2023, 11:53 AM   #2
ZL14ever
Drives: 2018 Camaro ZL1 A10
I thought it was already released for the A10? I think I saw something on Facebook
IMO, 2-step will still eventually push through the brakes. T-brake is the only solution to help build boost of the line
https://www.camaro6.com/forums/showthread.php?t=592876
ZL14ever is offline   Reply With Quote
Old 04-10-2023, 11:56 AM   #3
JP374
JP374's Avatar
Drives: 21 Lt1
Not yet. I’ve been talking with the developer and he keeps saying very soon.
21 Camaro LT1 Fully forged, Katech ported stock heads, P1X,3.7 upper and ATI w/ 8.25 lower, Stage 2 intercooler, Race B.O.V, Btr stage 2 blower cam, Btr Trinity intake, 103mm TB, F.I.C +30’s, Fore innovations, LPE big bore pump, Weld Lagunas Drag Pack. Circle D TC. Full Bmr upgrades, Keltrac rear shocks.
JP374 is offline   Reply With Quote
Old 04-10-2023, 12:22 PM   #4
BeauRichardson
[QUOTE=ZL14ever;11304239]I thought it was already released for the A10? I think I saw something on Facebook
https://www.camaro6.com/forums/showthread.php?t=592876[/QUOTE
probably only gonna take it to 2700 to 2800 RPM on the two-step. maybe 3k just want to be able to go full throttle so that I can start to build boost and get off the line quicker
Old 04-10-2023, 12:32 PM   #5
BeauRichardson
i’m super excited for that tbrake. i’ve told him that i’ll be getting one as soon as they’re available. really interested to see how far i can take this trans power wise. i think he said he’s making 900 something to the wheels
Old 04-10-2023, 07:08 PM   #6
Sillysspeed
Drives: 22 LT1
Been thinking about a 2-step for mine. P1x with lt4 fueling. I had one on my 4th Gen and foot braked it. Went my best 60ft with it. Procharger could definitely use it. Best 60ft I’ve been able to get with stock converter is 1.70
Sillysspeed is offline   Reply With Quote
Old 04-10-2023, 08:30 PM   #7
BeauRichardson
so you would definitely say that using a 2-step with procharger is helpful?
Old 04-10-2023, 09:18 PM   #8
Sillysspeed
Drives: 22 LT1
I had one on my turbo vette and my 4th Gen. They both worked well. I think it would definitely help the 60ft on the 6th Gen with Procharger. Go from leaving on no boost to a few psi
Old 04-11-2023, 08:19 AM   #9
BeauRichardson
right on, hopefully the weather stays clear so i can get out and do some testing and i’ll see if i can’t push it to 3 psi. i’d be happy with even 2
Old 04-11-2023, 09:16 AM   #10
JANNETTYRACING
JANNETTYRACING's Avatar
I lighter spring in the Bypass can correct that.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 04-11-2023, 09:45 AM   #11
BeauRichardson
i was unaware that the spring in the procharger blow off valve was able to be changed! that is very nice to know. so how exactly does that correct it? and do you guys sell springs?
Old 04-11-2023, 09:48 AM   #12
JANNETTYRACING
I just assumed, (my fault) you had the race bypass.
If you don't you can move to a Tial Valve we carry with a very light spring.
203-753-7223
It closes with a lot less throttle input.
Old 04-11-2023, 10:02 AM   #13
BeauRichardson
203-753-7223
i had to go double check the order but it appears that i indeed did upgrade to the race bypass
Old 04-11-2023, 10:15 AM   #14
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
Something else is wrong. Why are you only able to go half throttle?
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
10 speed, 2 step, boost, cammed, procharger
