04-08-2023, 04:54 PM | #1 |
Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
Cam Driveability
I'm considering adding a mild cam to my ZL1 at some point this year, not looking for a huge bump in power because I already have more than I can use on street tires but the additional fueling is obviously a plus and being honest I just want a slightly choppier idle but nothing too serious so it will likely be a stage 1 or 2 cam depending on the manufacturer. My question for those of you have cams installed.
1. Do you notice ANY loss of drivability at idle or right off-idle? This is REALLY important to me so when I ask this, I'm asking for 100% honesty, not minor issues but you have learned to live with it. 2. Did it shift your torque curve upwards or did it just add more power up top without affecting the torque off idle? 3. Anything at all you regret about your cam install? TIA |
04-09-2023, 12:19 AM | #2 |
Drives: 18 ZL1-1LE, 10 JKU Join Date: Jul 2018
My car has always has a really bad off idle dead spot, even when it was stock. I probably should've had tuner address it more but I was already used to it and the car runs great. The only thing I regret is when I did the cam I also did headers and it is just a little too loud and loses tone, some blat it sounds like, in the mid range...but not the cams fault. People who know cars love to hear it as its sorta rare these days, and I fully admit I did it mainly for the fun noises
04-09-2023, 05:56 AM | #3 | |
04-09-2023, 07:16 AM | #4 |
Drives: 19' ZL1 A10, w/pdr Join Date: Sep 2014
I have a BTR stg II cam. I have no stutter on takeoff and it drives as normal. It does rock the car some at stops with a little bit of bucking but, nothing serious. I might get a different tq converter at some point but, in no hurry. The tune is the most important part of the install and determines how much cam lope you will get. I also had a TCM tune at the time of my build and shift points were addressed. Can't over emphasize the tune. Here is my cam video.
https://youtu.be/5-SbXrhN8nU
BTR Stg II cam w/ 38% fuel lobe, ARH 2" headers into 3" w/cats, Kong X port, Weapon X triple ht exchangers, NW 103, Rotofab big gulp, DSX lowside, TCM tune, BMR Lockout, Mustang dyno 720 rwhp, 634 rwtq on 93 pump.
04-09-2023, 07:38 AM | #5 |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
I haven't tuned a 6th Gen camaro cam yet, so take this for what its worth:
My experience tuning a couple of 5th gen ZL1 cams- since the blower cams typically have zero overlap, plus or minus, it's pretty easy to get them to play nice off idle and low throttle. The bigger overlap stuff on N/A cars is where you have to adjust more in the tune. Again, haven't done a gen V gm computer with a cam yet, but even with the torque based control, dynamics are still dynamics, so I assume it to be similar.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // Elite Ultra CC // BMR MM
Past Rides- 2014 ZL1 M6 Red Hot | Tons of mods 2004 CTS-V M6 Silver | Many mods 1995 Corvette M6 Torch Red | A few more mods 1992 Camaro M5 White | A few mods |
04-09-2023, 09:11 AM | #6 | |
04-09-2023, 09:22 AM | #7 | |
04-09-2023, 10:34 AM | #8 |
Drives: 98 Camaro Join Date: Apr 2022
Check out Cam motion. They have some nice stage 1 and 2 camas that also have the 38% fuel lobe. I also believe they have the best quality cam cores available to the masses
04-09-2023, 10:58 AM | #9 | |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
I have their PD Stage 1 cam (220/236-118) with an overlap of -8° it idles as smooth as stock. Which was important for me with our strict emission laws. Driveability is awesome, it drives just like oem. With the mods in my signature peak torque is at 4500rpm. My only regret is that I only went with the 32% fuel lobe, but back then I was not planning to take the build as far as where i'm at with it today. Judging by your questions: you should try to keep the overlap as small as possible for driveability, and off idle torque. But you won't get the coppy idle with that. "Less overlap increases efficiency by reducing the amount of raw fuel that escapes through the exhaust, while improving low-end response due to less reversion of the exhaust gases back up the intake port; the result is better idle, a stronger vacuum signal, and improved fuel economy."
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 Last edited by swisstyphoon; 04-09-2023 at 11:33 AM. |
04-09-2023, 11:50 AM | #10 |
Thanks guys. I'm familiar with cam overlap and lobe separation and it's effects on idle quality. Just curious to hear your experiences with a cam in this platform specifically.
04-09-2023, 09:25 PM | #11 |
Drives: 2017 ZL1 Join Date: Aug 2020
I believe on my rebuild we used a 32% cam. Idle is a little choppy which wasn’t something I was necessarily looking for. Recently been having a surging/bucking issue at part throttle and since I no longer do rodeo I opted to get it back to the shop to address that in the tune.
I know this isn’t part of the hot rod priority, but mpg when cruising at 65mph was 25mpg before the cam and sc porting and now it’s around 19-20. Noticeable when jamming on a road course. |
04-10-2023, 03:52 AM | #12 | |
04-10-2023, 09:16 AM | #13 |
I would recommend keeping the intake duration under 220 with a 114-115 lsa and it should produce a mild lope and maintain close to stock driving manners.
The new revised BTR cams are pretty solid. Stage 1 PDS or Supercharger would be a good option for most builds. No need to go any larger unless you are shooting for 1000+ whp...otherwise you are just sacrificing drivability for a few extra hp. The stage 2 stuff really needs a converter even though some claim it works with stock vert. It does but it's on the edge. Don't listen to anyone who says "I run a stage 3 and it drives like stock, it's all in the tune". No it doesn't and no it's not. Some peoples view on what can be considered "stock like" is skewed. While proper tuning is critical you can only do so much with a cam that has positive overlap.
2016 NFG 1SS A8
04-10-2023, 09:23 AM | #14 | |
