![]() Drives: 2022 LT1 Join Date: Aug 2016
Service Pricing
2 time Camaro owner, firsts a 2016 2SS and now a 2022 LT1. My 2016 service prices for oil changes were always around $70 at the local Chevy dealer using the recommended fluid. My first oil change on my LT1 was about $75 and that was September of 2022 at dealer number 1. I stopped back to dealer #1 last week and was quoted $150 for oil change and $280 for rear diff oil change.
I called around and received the following quotes Dealer #2 oil change $220 rear diff $220 Dealer #3 oil change $ 180 and rear diff $200 Yes I can do it myself but this old man doesn't like rolling around on the ground anymore. Just wanting to hear current feedback from the members as I am sure this has been talked about before |
Moderator
You realize that the LT1 engine holds 10 quarts of oil right…? Anyone doing a $70 oil change is losing their shirt.
Edit: just looked up my last order for oil & filter from Driven Racing Oil, it was $144.97 plus shipping just for the oil and filter (did the labor myself obviously).
![]() ![]() ![]() ![]() ![]() ![]() Drives: Wild Cherry LT1 Join Date: Dec 2016
10 quarts of 0-40 dexos 2 is anywhere between 9 and 11 bucks a quart (retail). And the filter is anywhere between 5 and 10 bucks. You can can get deals on the oil and filter.. but they’re far and few between. IE. I just paid $62 for 10 quarts of oil, that will be after I return the 2 $10 non GM oil filters that come with the “deal”. You could search out these deals and bring the oil and filter to a mechanic (if they’re ok with that), but your savings won’t be much from the $180 figure (especially if you put a value on your time and effort). 10 quarts takes a while to drain and fill, then there’s the waste fee.
The diff fluid cost seems a bit high to me. The fluid itself is expensive, but we’re only talking about 1.2 quarts or so. Then take into consideration they already have the car in the air changing the oil. Seems expensive.. |
#4 | |
Moderator
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Nothing is cheap these days. I have to take my Harley in next week for some maintenance. They are now charging $150/hr. I recall when they used to charge $60/hr.
You have to pay to play. Toys are never cheap. I'm just thankful I can own the toys I do and not have to worry about the cost of them. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
I can get the 0W-40 M1 Supercar for ~$100 for 10 qts. Then the filter is ~$10.
So $110 for the parts, Give or take items on sale and bulk etc... You decide if the labor is worth it.
<Insert Cars You Own Here>
#7 | |
![]() ![]() Drives: 2023 Sharkskin 2SS Join Date: Oct 2022
The one time I was lazy and this is what I got for my free oil change. (been changing fluids since 1975) |
#8 |
![]() Drives: 18 Camaro 2SS Join Date: Jul 2022
Service
One advantage if having a GM dealer do your maintenance. There will be a record of the work that was done in case of any warranty problems that would arise.
#9 |
![]() ![]() Drives: 2017 2SS Arctic blue fully loaded Join Date: Mar 2021
500 USD an hour for a franchise dealer to work on you car here lol..plus 25% taxes.
i do what i can myself. buy my oil from germany. here in sweden EVERYTHING is a colossal rip off. 5 USD for a small loaf of bread lol. ok we earn quite good but come on
#10 | |
What I was alluding to was even if he got a retail deal on the oil and filter, he’s not going to save much bringing it to someone else, so the price is what it is. He can figure out whether there’s value in one stop shopping. I would say yes, there is. The cost is higher, but there’s less hassle. However, I stick by my commentary on the diff fluid change.. If he was bring the car in for JUST that service, I’d say sure, the cost makes sense (at a dealer). But, if he’s doing both oil and diff, it literally takes a few minutes more time to change the diff fluid, while the car is already in the air (and the engine oil is draining) Again, he can figure out how he wants to deal with his service. Sometimes you can get something cheaper by doing a bit more work on your end, or asking questions, just as he’s done here. Is it worth it? I can’t say for sure since I do my own fluid changes. |
#11 | |
Moderator
#12 |
my dealer wanted 150 for the oil change which I knew but they told me $280 total to do oil and diff. $130 more for 2qts of diff fluid and MAYBE 5mins work on the lift
2022 1SS 1LE 6M in Riverside blue
Found exact build local- ETA 7/31/22 New ETA - 7/26, 7/30, 7/31, 8/1, 8/8, 8/15, 8/21, 8/28, 9/17 8/24. IT HAS ARRIVED at the dealer 8/25- It is in the Garage ACS ZL1 Sideskirts, 20% tint, CAI Intake |
#13 |
![]() ![]() Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
Cheapest I got 10qts and filter was $80 and that's cause someone sold their car and had a kit left over.
Usually I'm right around $110-120 if I do it myself. At the dealer I wanna say I'm around $150. |
#14 |
![]() Drives: 2016 Camaro 2SS "Convertibobble" Join Date: Mar 2022
I don't believe that dealers are going to "cut a deal" for anyone simply because, in this instance, the car may already be up on the lift. Hasn't it been some time now that almost all of them use some bogus system of standardized "task times" for calculating unit labor charges? So they're not gonna say, OK, it was 0.75 hours for the oil change, but only five minutes for the diff fluid. Nope, 0.75 and 1.25, or whatever, because, sir, "that's how 'our system' charges for it."
If you were a very good customer and were to politely, but unmistakably let them know that YOU know that the $280 figure is excessive, and for this exact reason, then MAYBE somehow they could find some sort of "shop discount code" they could apply to part of the work. But probably not, and otherwise, no, I would not expect them to do that at all, which is why one should probs maintain a solid relationship with an individual shop, or do work like this oneself.
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp) '99 4Runner 367K '94 ST1100 146K |
