Old 04-06-2023, 04:01 PM   #1
viiv
Drives: Nissan 370Z
Couple of Questions Regarding a New Camaro Build
If you order the Recaro seats on a base 1LT 2.0T, do you get the heated and cooling function? Do you get the rear leather seats? Do you get any other material upgrades like in the door cards?
In regards to wheel selection, on the same base 2.0T car, will the stock 18" wheel be lighter and provide me with better fuel economy than any of the 20" upgrade wheels such as the 20" 5-spoke, Carbon Flash-painted aluminum wheels?
I notice the LS model comes with different split-spoke 18" wheels than the LT model. Any one know which of these wheels is technically better and lighter? Thanks!
viiv is offline   Reply With Quote
Old 04-06-2023, 04:43 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
If you buy just the Recaro seats alone, I believe all you get is the Recaro seats. You will not get heating/ventilated functions with a 1LT, it would be given if it was a 2LT (or 3LT) that already had a heated/ventilated function.
I don't believe you get the rear leather seats but not 100% sure about that.
The most significant difference in the wheels will be the style and ride quality from 18" to 20" (same with run-flat vs non-run-flat).
If you want lighter wheels, the option would be the forged wheels that come with the 1LE package but unfortunately, they removed the 1LE package from LT trims a few years back. I believe the difference between the LS and LT 18" wheels is just design, the LT gets split-spoke 18" while the LS is not split-spoke. Though from some other threads, the difference between the forged and aluminum wheels is maximum of 10 lbs. Forged around 25-26 lbs and aluminum hovering in the low 30 lbs.
2016 1LT v6
- Totaled
Happiness: Infinite
Old 04-06-2023, 05:09 PM   #3
Anjilslaire
Anjilslaire's Avatar
Drives: 2021 3LT RS A10
If you';re looking for fuel economy improvements between 18"-20" wheels on a Camaro, look elsewhere for a car, perhaps.
Also, per another thread, there will be no 2.0 on the 2024 model year.
Anjilslaire is offline   Reply With Quote
Old 04-06-2023, 05:14 PM   #4
Junction65
Junction65's Avatar
Drives: 2011 GMC Sierra 1500
Can't speak to an 1LT but on a LT1, if you order Recaros you get no heating/cooling however you do get full leather rear seats. The "knee pads" on the door and the console are still plastic.
2023 LT1 M6 Coupe - Black (GBA) on Black (H1T) - Build Date: 8/22
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W)
LT1 PBC engine - Shane Parker
Current mileage: 400
Junction65 is offline   Reply With Quote
Old 04-07-2023, 11:25 AM   #5
Linker239
Linker239's Avatar
Drives: 2022 WC 2SS
Yeah 100% correct. To be honest the plastic knee pads haven’t bothered me as much as I thought they would. I still want to change them out for something nicer, but it went down on the list a bit.
Current 2022 Wild Cherrry 2SS; Recaros, NPP, 5 Split Spoke Polished Rims, Satin Black Package
Ordered 7-11-2023 1100: Riptide Blue 2SS, Not Built
2023 Red Hot 1LT RS V6; Sold
2010 VR 1LT RS; Sold
Linker239 is offline   Reply With Quote
Old 04-07-2023, 11:59 AM   #6
Junction65
Junction65's Avatar
I went back and forth about replacing the plastic pads. I ended up purchasing a 2SS leather set from the classifieds board. Got them installed and it was the finishing touch to the LT1 Recaro leather interior.
Old 04-07-2023, 12:37 PM   #7
Linker239
Linker239's Avatar
Drives: 2022 WC 2SS
That’s sounds like a pretty good deal. I was pondering on getting a set of alcantra knee pads to match the seats. But now I’ve got the Itch for a V8 so we will see what happens.
Old 04-07-2023, 12:41 PM   #8
Capricio
Drives: 2000 WS6
You're probably already aware, GEN5DIY makes a cooling control kit you can use to add that function to seats that don't come with console controls for it. I think the hardware in the seats is already there. Not sure about adding heat, probably takes a lot more current than controlling some fans.
Capricio is offline   Reply With Quote
Old 04-07-2023, 03:59 PM   #9
Bumbleboy92
Long hauler
There’s no current solution to adding OEM heat, the hardware I’d imagine is there similar to the cooling function. But Gen5 doesn’t have anything for it as of yet, their cooling harness is nice though.
2016 1LT v6
- Totaled
Happiness: Infinite
Old 04-07-2023, 07:43 PM   #10
buckwam
Drives: 2021 camaro 1ls
The split spoke wheels on the LS are only 7.5" wide and the 18" wheels on the LT are 8.5" wide. I would think the narrower wheels are lighter but not sure how much?
buckwam is offline   Reply With Quote
