Old 04-06-2023, 05:34 AM   #1
B81jll
Drives: Chevy Camaro
10 speed tuning after circle d stall
Does any have a starting point for tune on the A10 transmission after installing a circle D Na stall, my car has heads cam intake and supporting mods. after stall converter install the shifts from 1-2 2-3 3-4 kinda feel loose and like its searching for what it needs to do instead of a firm lock up and pull
B81jll is offline   Reply With Quote
Old 04-06-2023, 09:05 AM   #2
jlaudio11
jlaudio11's Avatar
Have you done anything with the stock tune yet? Converter lock up, converter slip, and having maf/ve dialed in so it sees the torque correctly are all things i would be looking at.
'20 Camaro LT1
Twin 67/62 turbo 401(L8t) Texas speed forged piston & rod, BTR stg1 turbo cam, holley ultra lo, port injection, circle d 3600 stall, et street r’s on racestar recluse wheels.
1.33 3.75 5.75@122.98 1/8 pb 9.04@141 1/4 pb technically
'94 Camaro Z28 6mt cc306 cam, 4:10's, longtubes with x pipe, otr intake
jlaudio11 is offline   Reply With Quote
Old 04-06-2023, 11:29 AM   #3
B81jll
tcm
yes ive got everything seems to be really nice except the normal low speed driving it pulls good on a hard pull just the low speed sucks
Old 06-05-2023, 11:59 AM   #4
Dynamical
Dynamical's Avatar
Drives: 2022 Camaro LT1 A10
Any luck? What stall speed did you go with on the Circle D? Do you know what the stock stall speed is? What year is your car?
Dynamical is offline   Reply With Quote
a-10, transmission tuning
