Old 04-04-2023, 09:13 PM   #1
2022csilv
2022csilv's Avatar
Drives: 2023 Riverside Blue ZL1 A10
Hey Guys...Break in period
Do I have to drive this thing cautiously for a period of time? Should I open it up (full throttle) here and there in the first 500 miles? Suggestions?/
2022csilv is offline   Reply With Quote
Old 04-04-2023, 09:19 PM   #2
Carzzy
Carzzy's Avatar
Drives: '24 Camaro 2SS Conv. & '21Blazer
Keep your RPM's under 4000 and vary your speed for the first 500 miles. I would not do any full throttle take offs for the first 500 miles.
'24 Camaro 2SS 6M Convertible
Carzzy is offline   Reply With Quote
Old 04-04-2023, 09:25 PM   #3
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
This! Give it at least 500 miles of easy driving (I would even recommend changing the oil and diff fluid at 500 miles), after that you can drive a bit more aggressively, technically the manual considers the break in period to be 1,500 miles, but most people consider the first 500 to be the most critical...
Old 04-04-2023, 09:26 PM   #4
ariZona28
Give speed a chance
ariZona28's Avatar
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28
Hot DAMN that is a beautiful car. The more I see that Riverside Blue the more I like it. Good luck keeping your foot out of it for 500 miles even if it's the right thing to do.
ariZona28 is offline   Reply With Quote
Old 04-04-2023, 09:27 PM   #5
JTS
JTS's Avatar
Drives: 2023 ZL1 A10
I have my very good friend, that has been ,building Engines, Performance and Daily Drivers for over 50 plus years, I've had and helped him build my engines , I called him and suggested,1 st 400 miles ,4k rpm max accel and decel , 80 mph , very speed , 500 miles up 5k rpm accel decel an 80 mph . At 1k miles you can pull to 6k , after 12 to 13 hundred, you good . Or follow the OM. Oil change and Diff 5 to 700 miles .
I followed his or OM suggestions, but all up to the individual.
2023 ZL1 A10 Shadow Gray Metallic
JTS is offline   Reply With Quote
Old 04-04-2023, 09:29 PM   #6
Silveradoss573
Drives: Camaro 1LE
Owners manual pages 191 and 192....check it out
Silveradoss573 is offline   Reply With Quote
Old 04-04-2023, 09:39 PM   #7
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
I recommend you do your own separate research since most people on here aren't automotive engine engineers or performance engine builders, but it's important to get some good runs in early in the engine's life to seat the rings. The heat and pressure are needed to properly seat the rings. The process performance engine builders use is essentially: Set it in manual mode, start in 3rd gear @ 2000 rpm. Roll into near wide-open throttle to 4875 rpm (75% of the 6500 rpm redline), then engine brake (stay in 3rd gear) back down to 2000 rpm. Do this a few times, drive around and let it cool down, then do it again.
Again, I recommend you research this technique before you do it. It's what I do with my new cars, but again, don't take only my word for it.
Whatever you do, don't baby the thing for 1,500 miles.
Change the oil at 1,000 miles and then go off the oil life counter after that. I'd suggest doing the rear differential with OEM fluid at 1k miles, too. I waited and did my rear diff fist change at around 4k miles at my 2nd oil change.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 04-04-2023, 09:56 PM   #8
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Go with the recommendations in your owners manual. It’s not rocket science.
Old 04-05-2023, 01:21 AM   #9
DangerZL1
Drives: 2023 Black ZL1 Auto
I’d go with the recommended break in too. It’s not just the engine that’s breaking in. The ring and pinion need to be heat cycled too. My MPG went from about 12.5 when new to 16 Avg after a few weeks. This shows how tight a new engine is.
Old 04-05-2023, 05:15 AM   #10
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Start at step 6 (1-5 were done at the factory). Skip step #10 and do the 1st oil change at 500 miles.
Wait until 1500 to take it to the track, then do a proper prep per the track prep guide. Also, the tires will try to kill you in rain. Warm dry pavement is your friend.
Old 04-05-2023, 08:35 AM   #11
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - All Bolt On's
Welcome to the ZL1 Club! WOW!!! I didn't follow any of the above break in routines! I hope nothing comes back and haunts me! At 180 miles, 90 of which were from driving back in a rain storm from the dealer on December 14th 2022 when I bought mine. Shortly after, I began ripping her apart and started my mod process, added long tube headers, secondary CAT delete, exhaust mid-pipe/x-pipe, Corsa Xtreme NPP, throttle body, intake, new coil packs, gauges, valve covers, plugs, wires, and just ended my mods by adding a DSX Flex Fuel kit and a few other goodies! Tuning process during my mods, with 378 miles on the odometer, I started the process that included a total of 5 different computer flashes, which required doing pulls from 2000rpm to 5500rpm/6500rpm. My tuner confirmed his changes are tweaked best they can be and she's good as is, and yes, she’s a BEAST! I have 570 miles on her now and I love cruising around through our busy town now that the weather is nice, tons of people walking around the stores and the restaurants and coffee shops, and almost all of them turn their head and look when I'm passing by! This is a dream car to have and I feel very fortunate I have one! Have fun with yours!!! Attached is the fastest I've been on (4) wheels... It was a 7th gear pull, she was smooth as glass during the entire pull (in Mexico) I had to back off cause I was a bit un-nerved at that speed!
Old 04-30-2023, 11:13 PM   #12
boss2k
Drives: 23 ZL1 M6
I did and page 192 does not talk about changing engine oil at 500 and 1500 miles. Can you point me to the documentation regarding this?
boss2k is offline   Reply With Quote
Old 04-30-2023, 11:14 PM   #13
boss2k
Drives: 23 ZL1 M6
Thanks where did you find this detailed steps?
Old 05-01-2023, 09:39 AM   #14
JSH
JSH's Avatar
Drives: '20 ZLE
My engine was modified and dyno'd several times three years ago with 375 miles. It doesn't consume any 5W30 oil and has no issues.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
