Old 04-04-2023, 02:37 PM   #1
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
Trans Fluid System
Having my filter changed, Mechanic I went to says his system is telling him my car has a 8.1 Qt trans fluid system, but when I bought the AC Delco trans fluid from Rock Auto it said it was a 3.7 Qt system.
Does anyone know how many quarts I need for this?
Old 04-04-2023, 04:44 PM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Have you looked at the owners manual? The answer is in there.
If you or a previous owner have lost the book, you can view and download the OM at chevrolet.com.
Old 04-04-2023, 05:52 PM   #3
FlukeSS
FlukeSS's Avatar
Never had a book with the car, but chevrolet.com it is
Old 04-04-2023, 05:56 PM   #4
FlukeSS
FlukeSS's Avatar
So ya, now I get a bunch of different numbers.
8.1 - Mechanic
3.4 - Camaro 6 forums
3.7 - Rock Auto
10 - Trans flush (which is not what I'm getting) - Bill Estes's Chevrolet
and more results from Camaro6 Forum which are not applicable
Originally Posted by DIYguy View Post
According to the FSM I have-
Pan drain and filter- 7.0L/7.4 qt.
Overhaul- 10.3L/10.88 qt.
Complete w/cooler- 10.8L/11.41 qt.
This is for an 8AT transmission
Think I'll hold off until someone can hopefully answer without pointing to the search button.
If that worked for me I wouldn't have started this thread.
Old 04-04-2023, 06:35 PM   #5
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
8.1 - Mechanic
3.7 - Rock Auto
Yep, pretty amazing this information isn’t readily available for the 10L80.
I’m asking a similar type question in the transmission section and not a peep.
I’ll probably just buy a 3 day subscription to AC Delco, copy what I can and move on.
Old 04-04-2023, 06:44 PM   #6
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
3.7 is a drain and fill, not including the converter, cooler, & lines etc
Old 04-04-2023, 06:56 PM   #7
Rock-It Man
Wow. OP is right. This info used to be in the OM, but not anymore.
So now it's about following the flush and fill procedure in the shop manual. I would have a dealer do it.
Old 04-05-2023, 07:42 AM   #8
FlukeSS
FlukeSS's Avatar
The whole thing I wanted done is to get the trans filter changed.
Is that a drain and fill?
The mechanic said we aren't supposed to flush the trannies until after like 70k+ miles?
Either way I picked up another 5 qts of trans fluid, giving me a total of 9 qts. JP said his 10 speed took 9 quarts. I don't know if that changes though as I think he has a 10 Speed LT1 with procharger.
Old 04-05-2023, 08:21 AM   #9
ember1205
Hot Camaro
ember1205's Avatar
8.1 - Mechanic
3.7 - Rock Auto
Given that the owner's manual says "this process is difficult and should only be done at the dealer" with regard to even -checking- the fluid level, it sounds like you need a service manual to give you details. I know that @arpad_m has a service manual, but he also has an older Camaro and it probably doesn't reference the A10.
I'm not saying this applies here, but my wife's Acura RDX holds about 3.5 quarts of ATF but it requires 10 quarts to do a factory spec'ed fluid change and it's because of the process: Drain, fill, drive 100 miles, drain, fill, drive 100 miles, drain, fill. It's total overkill. Also, the mechanic I use for most stuff (independent) has told me that the service process on transmissions is to exactly measure how much fluid you drain out and replace that amount only. This ensures that the exact proper amount is in the entire system, including the torque converter, since the amount that drains will vary depending on how much is actually in the pan at the time the plug is removed.
Old 04-05-2023, 08:29 AM   #10
FlukeSS
FlukeSS's Avatar
Ya my mechanic, the device they use to drain failed, so he was going to get it fixed before doing the work on my car.
But yes they have to measure exactly how much to pull out, there's not dipstick of sorts to check.
His computer system was saying 8.1 qts, I do have 9 qts of the trans fluid though. If some of it doesn't get used no big deal to me.
Old 04-05-2023, 03:11 PM   #11
johnd5412
Drives: 2020 LT1 convertible
took me a while to find the fill plug on the A10 transmission as mine has a noise reduction cover. Plus the standard allen wrenches won't fit in the tight space to remove the plug and vacuum the oil out of the pan. I have almost 30K on my car and my intent is to replace the filter and only the oil that I drain from the pan. i bought some snub allen wrenches and hopefully that will work. If not, I have no idea (other than dropping the pan and spilling oil) how to remove the plug. Such a crap design.
johnd5412 is offline   Reply With Quote
Old 04-05-2023, 03:41 PM   #12
ember1205
Hot Camaro
ember1205's Avatar
This could all be related to why you're getting different answers. One is capacity while the others are how much fluid is used for -their- services.
Old 04-07-2023, 05:32 PM   #13
Chutzpah
Chutzpah's Avatar
FYI
