Old 04-02-2023, 08:46 AM   #1
Riding Dirty
Riding Dirty's Avatar
Drives: 19 ZL1 1LE
Slicks with felt wheel liners???
Question for those who are running slicks at the track. I have heard that the felt liners will get destroyed over time from tire snot getting thrown against them repeatedly.
What have you done to protect them?
Riding Dirty is offline   Reply With Quote
Old 04-02-2023, 08:44 PM   #2
laynlo15
Drives: 2022 Lt1 A10
Not sure where you read that, but I've run slicks on my 16 Ss (28x10-17 Hoosiers) and running them now on my 2022 Lt1 and not issues ever. I've run 146 on my 16ss and 142 on my 2022 SC, THPSI Lt1 and never even close to touching. If you caster is off you could touch the inner liner, but if its aligned correctly it should never touch. If your doing a burn out in the water box your gonna pull rubber from a slick or a drag radial. The proper burnout doesn't require destroying the slick or drag radial, in 55 years I've done thousand of burnout in the water box, a little smoke and you should be ready do go.
Old 04-02-2023, 09:20 PM   #3
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Originally Posted by Riding Dirty View Post
Question for those who are running slicks at the track. I have head that the felt liners will get destroyed over time from tire snot getting thrown against them repeatedly.
Well I have NEVER run into an issue running slicks at the track in regards to inner liners and I track 3-4 times a month.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 04-03-2023, 02:48 PM   #4
Riding Dirty
Drives: 19 ZL1 1LE
I was referring to road race tracks with slicks on. When you get off line to pass you pick up a bunch of shredded rubber. The concern is the wiring harness in the rear wheel well getting worn through and wiring getting pelted. I had a guy at the track tell me it's a know issue. That's what I'm asking if anyone else has run into this.
Old 04-03-2023, 02:58 PM   #5
Riding Dirty
Drives: 19 ZL1 1LE
You sir are a track junkie lol. No worries I am too. I take offJuly and August to beat the heat, but still do close to 15 a year. About to step up to the slicks and want to make sure I cover my bases.
Old 04-03-2023, 03:47 PM   #6
sr71bb
sr71bb's Avatar
Well I run APEX 18 inch wheels and generally Michelin 30 65 18 slicks at ALL four corners so I never get any where near the the inner fender wells particularly on the REAR of the car.
Retired Cars BELOW:
Old 05-02-2023, 05:19 PM   #7
Riding Dirty
Drives: 19 ZL1 1LE
Definitely had some kind of problem. Is that from rubbing? I can see the harness I was talking about through the hole in the liner.
Has anyone relocated the harness or reinforced the liners and or both?
Old 05-02-2023, 06:13 PM   #8
Vigilante375
Drives: 2018 Camaro ZL1
You need to relocate the harness now before the tire eats it. That's what everyone does.
It's common knowledge that running anything taller than the factory spec tire that it'll do exactly this. Rubbing through the liner and destroying the fuel harness.
That's the only liner that has a wire harness running through it. Don't know why GM engineers thought this was a good idea but that's engineers for you.
