Old 04-01-2023, 06:12 AM   #1
Dutch1LE
Drives: Zl1 1le
Race ramp wheel cribs
Anyone have any experience working under their car with the wheel cribs? I am looking at getting one set of the split 12 inch cribs. So you end up with four six inch cribs. Does anyone know if this will give me enough room to get under the car to perform dif, trans, oil, fluid change? I am not a big guy. Anything over 8-10 inches looks sketchy to lift that high with a single low profile jack. Looking for anyone’s input using this method. Also trying to do the most economical thing as they are expensive.
Dutch1LE is offline   Reply With Quote
Old 04-01-2023, 06:48 AM   #2
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
I use the exact set up.
then put floor jacks under the ZL1 lift pads for added safety (each side)
Old 04-01-2023, 08:39 AM   #3
Dutch1LE
Drives: Zl1 1le
Awesome. That’s exactly what I planon doing. Do you feel you have plenty of room to perform those jobs with the 6”? Also, what’s the sequence of lifting the vehicle? Do you lift one entire side of the vehicle and put the cribs in? Then go to the other side?
Old 04-01-2023, 08:51 AM   #4
302crossram
I'm 170# with 10% bodyfat.
I fit fine underneath even with a creeper
YMMV
I lift the front first with the wife unit lifting
the other side simultaneously (2 floor jacks) and then the rear.
reverse to lower it
Old 04-01-2023, 10:24 AM   #5
HemiDave
HemiDave's Avatar
Drives: ZLE/DEMON/GLADIATOR/GSXR1000R/ZX10R
"The Wife Unit"...
2018 Dodge Demon #1399
2020 Jeep Gladiator Rubicon 6 speed manual
2023 ZL1 1LE 6 speed manual
2018 Suzuki GSXR 1000R
2021 Kawasaki ZX10R
HemiDave is offline   Reply With Quote
Old 04-01-2023, 10:30 AM   #6
Dutch1LE
Drives: Zl1 1le
Yeah I’m 150lbs. So I should be fine. I only have one jack so I guess I’ll have to do side to side.
Old 04-01-2023, 10:40 AM   #7
302crossram
Originally Posted by HemiDave View Post
"The Wife Unit"...
Old 04-01-2023, 10:46 AM   #8
302crossram
that may be sketchy
at least get another jack and go side to side in 3" increments
until both wheels clear the cribs.
I would never lift one corner that high, too much could go wrong
jack may or will slide off the Lift pads, pinch welds could get damaged.
you got to get another jack amigo
(or buy a quick jack)
Old 04-01-2023, 11:16 AM   #9
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
that may be sketchy
Agreed. two jacks is the right way if you're trying to get all four wheels off the ground. The reason one jack is sketchy is once you get one wheel crib under the car (say a left front), only the right rear and the left front are touching solid ground. The right front and left rear are in the air and teetering back and forth. Super sketchy.
Ideally, you want to get wheel cribs under the front two wheels at the same time and then the rear two wheels (or vice versa).
Daytona jacks from Harbor Freight are fine and reasonably priced. Their low profile 3 ton jack fits under our cars well (although I do use a hockey puck to ensure clearance of the side skirts). I haven't tried the new 1.5 ton aluminum ultra low profile jack.
Hockey puck image attached
YouTube
Old 04-01-2023, 11:46 AM   #10
Dutch1LE
Drives: Zl1 1le
Yeah this is the whole reason I want to buy the cribs. I already have a low pro jack. Got the zl1 add ons lift pads. I also bought the mag pad and have hockey pucks. The cribs seem a lot safer than the jack stand on the pinch welds etc. I would really like to be able to use one jack. I was thinking I also have a set of ramps I made for my c6z because it was so low. What if I drive up on those first so the fronts in the air? That’ll put me about 5-6 inches off the ground in the entire front. Then could I jack one side of the rear up slide a crib in…move over to the other side, jack it up slide a crib in. Then if I want cribs in the front. It’ll already be up in the air on the ramps. At that point would I be able to jack from the rear a tad higher to slide the ramp out and a crib in?
Old 04-01-2023, 11:49 AM   #11
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Ramps are fine as long as you don't need to work on the brakes/wheels/tires. Also quite useful if you need to clock your bushings, presuming you have 4 and the car will be level.
Old 04-01-2023, 11:57 AM   #12
Dutch1LE
Drives: Zl1 1le
I have jack stands. When I do brakes etc I plan on just doing one corner at a time with the a stand
Old 04-01-2023, 12:26 PM   #13
302crossram
I paid $129 for my 3 ton Daytona low profile jack last year.
buy another jack my friend....
Old 04-01-2023, 12:44 PM   #14
Dutch1LE
Drives: Zl1 1le
Yeah your right it will make my life way easier. Were you putting your jack stands? Zl1 add ons says Do not put your stands on their jack pads. So right on the pinch welds? Don’t they get crumpled? I saw some rubber adapters for stands I may try. But even that seems sketch
