Old 03-30-2023, 08:23 PM   #1
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
Rear stud replacement
I’ve read all the informative threads on how to disconnect the rear suspension, pull the hub, and replace the studs. I’m good there. What I couldn’t find is if I need a rear end alignment after reassembly. Any thoughts would be appreciated.
Pcormier66 is offline   Reply With Quote
Old 03-31-2023, 06:48 AM   #2
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
not absolutely necessary as no toe or camber adjustments are touched to remove that hub. You will see when you perform that procedure it isn't a worry.
Old 03-31-2023, 06:53 AM   #3
Stephen12ZL1
Drives: '21 ZLE A10
https://youtu.be/2B37LdLxCWA
Old 03-31-2023, 07:52 AM   #4
Pcormier66
Pcormier66's Avatar
Drives: 2019 ZLE
Perfect. Thank you.
Old 03-31-2023, 08:24 AM   #5
Kerry
Drives: 2019 2SS Camaro
the alinement will be off. need to get it aliened after doing this.
Kerry is offline   Reply With Quote
