Old 03-30-2023, 02:06 PM   #1
Dennis 2ss
Dennis 2ss's Avatar
Drives: Camaro 2SS 2017
555R2s above 170 safe?
Hey everybody, my cars just about ready to get started on tuning and soon my first 1/2 mile event of the year is happening. Not even sure on the end speed i'll be getting but since i'm dumbass i didn't notice the 555R2s has a max speed rating of 170 which is my goal and maybe something above that. Do you guys think its still safe if i pass that speed as it's only for a second or two?
2SS A8 D1X Stage 2, 3.7 pulley, Kooks LT 2″, Borla XPIPE/ GPI drop ins,Caddy Racing Lifters, ATI Damper, LPE GT35 Cam 42%, LPE Big Bore, FIC 30% Injectors, Fore Twin intank pumps, Flexfuel, MM wild catchcan.
865 WHP 743 LB FT
2Forge 19" wheels daily, Forgestar D5 17" for track
Dennis 2ss is offline   Reply With Quote
Old 03-30-2023, 05:25 PM   #2
The Chief (tm)
The Chief (tm)'s Avatar
Drives: 2016 Camaro 2SS "Convertibobble"
1) Wow...
2) ...but I'd hate for you to find out the hard way! Please stand by for what I am sure will be some solid advice from the gang here.
'16 2SS Garnet Red ~24K
"Mods": GM wind deflector, home-made rear seat delete & platform, not-quite garnet red key fob cover (+10rwhp)
'99 4Runner 367K
'94 ST1100 146K
The Chief (tm) is offline   Reply With Quote
Old 03-31-2023, 11:47 PM   #3
The typical rationale behind these speed ratings is to quantify the tire's tolerance for heat buildup that happens during extended use at a specific high speed. That is, these are sustained speeds that the tire is expected to support indefinitely. (BTW, this is also the reason manufaturers, including GM, recommend much higher starting tire pressures for sustained high speed runs such as a standing mile or a max speed run to 190-200 mph and beyond.)
Consequently, I don't think a 7 or 8-second pass at the drag strip that results in these speeds for maybe half a second would cause a tire failure. Of course, this is just my common sense idea with zero guarantees, I'd also very much welcome the opinion of tire experts who may have ventured beyond rated specs.
Old 04-03-2023, 06:20 AM   #4
Dennis 2ss
Dennis 2ss's Avatar
Well put. I’m going with them this time. Not worried that much since i probably won’t reach over 170.
865 WHP 743 LB FT
