Old 03-29-2023, 06:33 PM   #1
JBones81
Drives: 22 ZL1, 18 RS3, 22 M3P
Just ordered a bunch of BMR goodies
Got the cradle guard stuff, along with some control arms and trailing arms. Glenn at BMR said these would do wonders for keeping the car straight. Hope he's right. After install I'll likely be in the market for some better tires, too.
Then, if the car is hooking up really well, I can start adding power and start the process of searching for traction all over again
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2024 Audi RS3
2022 Tesla Model 3 Performance
2018 Audi RS3 - Many mods & e85
Instagram - @JBsCars
JBones81 is offline   Reply With Quote
Old 03-29-2023, 07:38 PM   #2
GrayGhost1LE
GrayGhost1LE's Avatar
Drives: 2021 ZL1
You should like them, I do! Also installed front of rear cradle braces. You can see a small part of it near the 90° corner on the fender liner.
GrayGhost1LE is offline   Reply With Quote
Old 03-29-2023, 07:49 PM   #3
JBones81
I got that too, actually. It was like $120 so I just threw it in.
2024 Audi RS3
Old 03-30-2023, 07:06 AM   #4
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Ive now got the cradle lockout, a non-adjustable rear sway bar and end links, and the front of cradle braces. All great stuff. The rear sway bar was a real MF'er with the exhaust on the car.
Old 04-04-2023, 03:58 AM   #5
GrayGhost1LE
Drives: 2021 ZL1
Yeah! For the hassle of dealing with the rear sway bar, I'd just paint the oem one!
Old 04-04-2023, 09:30 AM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It helps if you've done an axle back, or just cut the pipes where an axle back would go so you could loosen the muffler. I think that's how I did it. It wasn't bad. I wrapped the tips in towels, too, so when it swung down-ward, the tips just didn't ramrod the facia. It wasn't bad after that.
'20 ZL1 Black "Fury"
Old 04-04-2023, 01:01 PM   #7
WhiteMale
I had the clamps loosened and off the hangers when the bar finally went through I was that close to dropping the AB to get it in.
