Old 03-28-2023, 01:56 PM   #1
marcgo2
marcgo2's Avatar
Drives: '16 Camaro 2SS Hyper Blue
Rear main seal replacement
So I have a very slow leak from the rear main seal. I got a quote on replacing it and it was $2500. I have not dealt with this before, is that a reasonable amount for this sort of thing?
Should I try one of these oil leak stop or rear main seal repair fluids or will that cause more problems?
marcgo2 is offline   Reply With Quote
Old 03-28-2023, 02:21 PM   #2
m6-lt1
m6-lt1's Avatar
Drives: 2012 Shelby GT500
I would not try any sort of “stop leak”. I would shop around for quotes. 2500 seems high. I believe the book calls for 8 hours of labor to r and r the transmission (I could be wrong about this). At say $115 an hour for labor I believe this job (parts and labor) should be between 900-1200 bucks.
m6-lt1 is offline   Reply With Quote
Old 03-28-2023, 05:59 PM   #3
haggler
haggler's Avatar
Drives: '23 2SS RSblue 6MT, sold '19 ND2
I wouldn't try a stop leak but you could try high mileage oil if its a slow leak.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars
EOS front splitter
5-6-22:1100,
7-19-22: 3000,
8-3-22: TPW 8/15/22,
10-4-22: ETA 10/13/2022
10-15-22 6000
haggler is offline   Reply With Quote
Old 05-08-2023, 09:30 PM   #4
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Switch to the Dexos2 spec oil if you haven't already. 0w-40.
wakespeak is offline   Reply With Quote
Old 07-02-2023, 07:04 PM   #5
olrocker
olrocker's Avatar
Drives: People crazy with my sexiness
A rear main seal on a rear drive car should be cheaper to do than a front driver. Dropping the transmission is super easy and quick on a rear drive car whereby a front driver you need to pull the axles, engine mounts, sometimes pull out the whole engine, and a whole bunch of stuff to get to the rear main seal.
Purchase order submitted on 6/23/23
Received and purchased 9/8/2023
2024 2SS 6MT coupe
Sharkskin/Light gray
Moonroof/Navi/NPP/Mag Ride/Red Brake Calipers
Gray painted split spoke wheels
Illuminated footwells/illuminated bowtie
olrocker is offline   Reply With Quote
