Old 03-25-2023, 01:06 PM   #1
427
Drives: Camaro
Electronic blow off valve
I'm in the middle of changing my car over for E85 and adding a slightly bigger turbo, the 54mm from ZZP. The turbo has a vacuum controlled blow off valve instead of the stock style electronic one. Has anyone deleted the electronic blow off valve? I would assume something in the factory ECU must be changed, but the directions did not call it out. It's getting a tune change so making changes will be easy if I know what is needed. Thanks in advance!
Kurt
427 is offline   Reply With Quote
Old 03-26-2023, 07:16 AM   #2
Davescamaro
Drives: Chevy camaro
Hey, I looked at the z54 turbo and where the bypass valve looks to be mounted uses the same 3 bolt pattern as stock, so any diverter valve may work. I won't guarantee it, but it wouldn't hurt to shoot them an email to confirm.
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears.
Davescamaro is offline   Reply With Quote
Old 04-01-2023, 10:59 AM   #3
427
Drives: Camaro
I ended up putting the electronic bypass on the new turbo, it was slightly different pattern but the new turbo housing was drilled for both the manual and factory electronic valve. I did contact ZZP but they didn't really know the difference between the valves function differences. Some research shows the factory valve is used in many systems for engine/trans/rear axle protection, so it's back in place!
Old 04-05-2023, 05:39 PM   #4
Davescamaro
That looks great! Glad to see it bolts on.
