03-22-2023, 12:25 AM | #1 |
Drives: 2020 Chevy Camaro ZLE Join Date: Jan 2023
ZLE with slicks
Anyone use slicks on the road courses? Wondering what your experiences were and if you had any issues with axles or anything breaking. Thanks!
03-22-2023, 07:35 AM | #2 |
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
Don't know of many issues like that, if you don't get the right sizes then it could screw with ABS at the limit. You will likely go through wheel liners pretty quickly too
03-22-2023, 09:10 AM | #3 |
I was going to run 305/680/18 in front and 325/680/18 in the rear
03-22-2023, 03:16 PM | #4 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
Unlikely, the 3R tires have nearly the same grip as slicks.
03-22-2023, 07:16 PM | #5 |
Drives: 2019 ZL1 1LE A10 Join Date: May 2020
abosoxfan4life, I run p-zero takeoffs in those exact sizes my car is definitely faster
with slicks. 3-4 seconds on a 1:54 lap. some people will argue this but for me personally that's my experience I also like the feel of slicks better. Just make sure to start with low pressure, I start about 24lbs and end up about 34 hot |
03-22-2023, 07:20 PM | #6 |
That's an interesting data point. My p-zero takeoffs on a SS 1LE are roughly 2 seconds faster over the SC3(Not R) over 1:40 laptime. But my experience is limited so far with used slicks, I've only used them during 1 track day so far and haven't tried different sets. Not sure how off the pace mine were from a new set.
03-22-2023, 07:38 PM | #7 |
Drives: 2021 1SS 1LE Join Date: Nov 2020
I bought a set of 18s to run scrubs, the issue is getting scrubs that are know to be good. I don't do that many days, but when I do, I need them to be good to go. I've seen 50% of the people that scrubs, have their days ruined by subpar tires.
Ken
Follow my build - https://www.camaro6.com/forums/showthread.php?t=594295
03-22-2023, 10:43 PM | #8 |
Yeah, I just have a hard time believing that used slicks can be 4 seconds faster than the SC3R, which is already at least 2-3 seconds faster than the SC3. that would put used slicks about 7 seconds faster than the SC3 and new ones 8-9s faster? It doesn't seem realistic.
03-23-2023, 08:26 AM | #9 | |
Ken
03-23-2023, 08:46 PM | #10 |
Drives: 1LE Join Date: Dec 2016
Think about the price difference. We can get 18" Michelin used slicks for a fraction of the cost of new SC3R.
03-23-2023, 09:02 PM | #11 | |
Ken
03-24-2023, 04:40 PM | #12 |
Do they have 19” slicks?
Orange Krush II
03-24-2023, 05:01 PM | #13 |
lots of people run slicks normally takesoffs on 18s
03-24-2023, 10:56 PM | #14 |
